I bought the 97 Z28 with the engine removed due to low oil pressure. My plan was to rebuild it and put it back in. Then I found a sweet deal on a low mileage engine out of a 94.
I know I need to change out the timing cover so I can have the CPS. Which means I have to use the vented opti from the 97 so I'll have to swap out the pins in the camshaft. I also know I'll need to use the 97 hub and reluctor wheel.
Will I need to change out the timing set as well? Or will the one that's currently on the car work? Also, is there anything else I'll need to change? I'll be using the 97 harness so there will be no issues with the opti. I do have all the parts from the 97's engine, I just need to know what all I need to swap over onto the new engine.
Thanks in advance for the help.
