Selling my 94 camaro t-tops white 6spd with lots of mods.
• 355 ci custom built motor, forged eagle bottem end with h-beam rods, balanced assembly, deck zero’d
• edelbrock lt1 rpm performer heads, redone with stronger valve springs
• comp 503 cam
• adjustable fuel pressure regulator
• ls1 coil conversion kit
• red top injectors
• pcm4less tune
• bbk shorty headers air pump fittings removed and heat wrapped to 3in pipes to a spin tech muffler with ss style exit pipes, also comes with cat to bolt in for emissions
• tremic 6 spd transmission with spec stage 2 clutch and fidanza neutral balanced flywheel
• 3in aluminum drive shaft
• 3:73 dts rear gear set and eaton posi carrier
• bmr adjustable panhard bar
• bmr front adjustable upper and lower control arms
• bmr rear control arms
• bmr weld in subframe connectors
• 17” eagle alloy wheels powder coated black-needs 4 tires and alignment
• kyb gas adjustable shocks with h&r springs-needs new springs right rear sags
• corvette c5 front brake conversion kit
• functional ss hood
• pioneer double din radio/cd player
• sparco racing seats
• fan switch
• air fuel and fuel pressure guages
• white face cluster
• hurst shifter and knob
i’m sure i’m forgeting somethings. I can produce receipts for most of the parts. All machine work was done at accurate machine in newport, delaware. Never had the car dyno’d after new motor and tune and suspension. Last run it did 13.2 @ 109mph on bald street tires. Im sure its well into the 12s now if not high 11s on a drag tire. Needs battery to run and tags are expired. Needs 4 tires and springs to be road worthy. Matching rear wheels are at work just have to bring them home. Body is straight but needs paint work, clear coat is peeling on roof area and spoiler from sitting uncovered. Motor and clutch have 150 miles on it and the trans and rear have about 30k miles. The shell has 174k miles. I have lost interest in the vehicle. I have over $10k invested into the vehicle. Looking for $7000/obo. Also interested in trades such as 4wd truck. I can send pics or setup a time to check out the car.
Link to Pics
• comp 503 cam
• red top injectors
• pcm4less tune
• fan switch
Link to Pics
