Posted: Mon Jan 02, 2006 5:53 pm Post subject: 9" Ford Rear
I am planning to build a 9" ford rearend,. I have a 4:11 chunk with a mini-spool .I have a housing lined up. How dificult is it to set up the mounts for the lower links and torque arm ? I know I will have to shorten the housing. It would be easier to just order a new one but that is not in my present budget. I also plan on building an adjustable torque arm that will connect to the cross member. Any of you been through this procedure, If so I can use some advice.
_________________
_________________
