Take your Chevy Camaro performance to the next level with K&N's® Blackhawk Series High-Flow Performance Air Intake Kit. This high-performance air intake kit is designed with specific modifications, like a free-flowing mandrel-bent aluminum tube and a low-restriction air filter to replace your vehicle's restrictive factory air filter and air intake housing. To maximize airflow, the Blackhawk System uses a custom designed and dyno-tested heat shield with an embossed K&N logo, making sure that cold, dense air runs through your engine while also keeping out engine bay heat.
The result? More power and acceleration than you ever thought possible. With the K&N Blackhawk induction system, your vehicle gets more air in its engine for improved throttle response and better performance overall. And since more air equals more power, you'll be burning up the roadways in record time! Take command of the roads with the superior performance enhancement of K&N's® Blackhawk Series High-Flow Performance Air Intake Kit for Chevy Camaro - guaranteed to give you explosive results in no time at all.
K&N® - Blackhawk Series High-Flow Performance Air Intake Kit
More details on - K&N® - Blackhawk Series High-Flow Performance Air Intake Kit
HP Gain: Up to 21 hp
TQ Gain: Up to 28.1 lbs./ft.
Series: 71 Series Blackhawk Induction®
Link to DYNO chart: https://images.carid.com/kn/items/pdf/71-3092-dyno-chart.pdf
Not sure how air intakes work? Read more in our article!
Performance Air Intake Systems: More Air Equals More Power
In this article, we’ll describe some performance air intake system variations among the available kits and also showcase a sample of them.
