I have a 95 z28 Camaro that won't shift 3-4 that was just built because it wouldn't shift 2 and 4 . It will go in 3rd when in limp mod . Anybody know what the problem can be ? I'm lost and tired of spending money
Welcome to the forum.
Have you tried hooking car's aldl to an obd 1 scanner & reading codes. There are some engine codes that cause trans not to go into every gear. And also trans codes. So get an obd 1 scanner and read codes. A running sensor scan wouldn't hurt either.
Even though your 95 has a 16 pin obd 2 type aldl connector, it is an obd 1 computer system. An obd 2 only scan tool will not read your car.
Did you return the car to shop that did trans work? I would think that you received a warranty when you had work done.
Go to the following link and download the 95 service manual. It will have troubleshooting, complete info on codes, etc.
