I have read alot on here about 383 stroker applications and head and cam applications i just want an opinion on what you guys think of this application i have picked out....my compression ratio should be 10.75.1 keep in mind i want to run pump fuel so i dont want to go to crazy with my compression ratio.
Heads:trickflow Bottem end:
Intake runner:195CC crank:eagle forged 3.75 stroke .30 over
Exhaust runner:75CC pistons: mahle -5cc forgerd
Combustion chamber:62CC Rods:6.000 H beam
intake manifold:edelbrock preformer RPM air gap
throttle body:58mm holly
Rocker arms: 1.6.1 non self aligning comp cams.
Fuel injectors:36#per hour accel
Camshaft:Comp Cams 292XFI HR13
Duration:intake:292
Duration exhaust:300
lobe seperation:113 degrees
Valve lift exhaust:.579
Valve life intake:.584
That is over all the main components i guess what i am asking is some opinions: and some improvements if anyone has any ideas
Thanks guys,:LS1LT1flag:
Duration:intake:292
