I am having trouble (PCM?) shifting and staying in 4th, it is behaving almost like it is in "Performance mode", but there is no performance mode on this car (see background).
Symptoms: have to be above 55 and foot nearly off throttle to get 4th. With even a small amount of throttle (20%), down shifts to 3rd.
PCM command is accurate, so I believe the problem is in the PCM or ?? did I miss a wire?
Background:
1994 Caprice LT1, 4L60E, Engine Swapped into Toyota Land Cruiser
PCM Speedometer corrected for new axle gearing (no other changes to PCM)
Speed Verified on Scanner
Gear Command Verified on Scanner
Background:
