3/4 clutch pack Clearance
45866 Views 48 Replies 12 Participants Last post by  stephx0609
ok i am up to this point i am trying to install the Alto "power pack" 9 friction kit and i have .107
at 9x.010 I need 0.090 min and .125 max for tote stack? 9 frictions is this right? or is that too tight?
can i use some of the old steels as the top spacer plate to adjust the Clearances? If I put the stock thick one back in I don’t have room at all...
If I need to ill take a pic on how I have them stacked up..
1 - 20 of 49 Posts
Yeah, usually the adjustment is made with the top plate. As long as the old top plate is in good shape and not burnt or warped you can reuse. I've used that alto pack with 9 clutches before and it didn't last very long. You really need to bring that gap down. You're measuring dry right?
www.wittrans.com they have top spacer plates of different thicknesses for adjusting the clearance of your 3-4 clutch pack, as well as the others.
there wet i was reading some people where saying .015 per stack
Yeah, I'm not a giant fan of the Alto 9 disc stack, either. Sure, you get 9 frictions in there, but you have sacrificed too much thickness on both the frictions and the steels to make them much good at tolerating heat. The Alto kits measure .062" on the frictions and .060" on the steels - pretty thin...
A 700R4/4L60E 3-4 clutch is kind of an anomaly of sorts. It's such a weak clutch design that convention kind of gets thrown out the window to make them last, but shift well. The thing that comes into play is not only lubrication and cooling of the plates (more clearance is better), but the quality of the 2-3 shift (less clearance is better). During the 2-3 shift, the transmission is releasing the band and engaging the 3-4 clutch simultaneously. When the valve body commands the shift, pressure is sent to the back side of the 2nd gear band servo and to the 3-4 clutch piston at the same time. The band begins to release almost instantly, so during the time between the release of the band and the engagement of the 3-4 clutch, you're, quite literally, in first gear for a fraction of a second. This is why it is so critical for the 3-4 clutch clearance to be as tight as possible, while still allowing the plates to lubricate and cool acceptably. The tighter the clearance, the less time it will take for the 3-4 piston and apply ring to travel the distance necessary to begin clamping down on the clutch plates.
In either case, .107" may as well be a mile... That's WAY too much clearance. You're right in that conventional thinking provides appx. .010" per friction in the stack for good lube and cooling. But, even .090" (9 x .010") is way too much clearance. Your 2-3 shift will be a bit of a lazy, slide-shift at low throttle and, under heavy acceleration, you're likely to have some flare, especially as the plates begin to wear and the clearance increases even further. When I use a 9 disc setup (not often), I use the red frictions and kolene steels and shoot for .030-.035", and definitely no more than .040". Transgo recommends .015-.020" in their shift kit instructions, but that's for a stock 6 disc stack. You won't get away with that using 9 thin discs for very long.
At the risk of giving away trade secrets, my preferred stackup, starting at the piston, goes like this:
-Bonded steel piston
-"7" apply ring (a "4" will work if that's all you've got, but pretty much all 4L60E's came with "7"s)
-Stock return springs
-Factory NEW 3-4 apply plate (OEM AC Delco only)
-7 Borg Warner high energy frictions (factory 4L60E plates)
-6 700R4 .076" steels (stock or kolene, your choice)
-Factory NEW 3-4 clutch backing plate (OEM AC Delco only)
-.093" snap ring
-This stack almost always comes out between .022-.025".
-On a high RPM application, I'll drill a .035" relief hole in the input drum at outer edge of the 3-4 piston bore to prevent centrifugal apply, thus dragging the plates unnecessarily.
One more thing... I ALWAYS use the load release springs in the 3-4 clutch. These are important when running a tight stack because they force the apply and backing plates apart when the clutch is released, minimizing drag on the plates between them. If yours are missing, or have lost their tension, get new ones and put them in...
Sorry for the novel...!
I've switched to the BW 7 disc setup this time around. Instead of drilling the hole though I chickened out and went with the rapid release valve.
ok well thanks for the info i though they where sending me a 7 disk set up not a 9 but o well lesson learned
what i am going to do is through the 3-4 pack in a Zip lock and put it away. use all the other Alto sets and order a 7 disk Borg Warner set or equivalent.
They don't necessarily sell a 7 disc "set". You'll just need 7 high energy frictions (you should have gotten 6 of them in the overhaul kit - just order one more), 6 .076" 700R4 steels new apply plate and backing plate. Make sure you order 700R4 steels, as the 4L60E steels are too thick for a 7 disc stack (.106").
I can't stress enough the fact that you need to replace those apply and backing plates, especially the apply plate. They warp and take on a "cone" shape through years of use. This becomes greatly exaggerated if the old 3-4 clutch was burnt up, which is very common. The heat generated when the clutch fails will soften the apply plate and cause it cone badly. If you put a coned apply plate back in, it will only apply pressure to the outer edge of the stack due to its cone shape. I have seen many a transmission guy pull his hair out with repeat 3-4 clutch failures due to not addressing this issue. The plates are cheap (relatively) and readily available from GM. I keep 4-5 in inventory at all times. Plus, they are slightly redesigned to improve their rigidity.
well that being said i am going to take this thing to a shop and have them set it up.... i can handle the rest of the asmbley my sealf i just dont have the time or the tools to get the "apply plate"
I didn't say all that to scare you off. It's really pretty simple to set up if you use the right parts the way I listed it out. You can get the apply plate from GM, or you can find it online. Just make sure that it's an AC Delco part. I think it's about $25 for both the apply plate and backing plate. Or you can always give me a shout and I can send them to you along with everything else you'll need.
Did you air check your drum with that valve installed?
I just tried to air check mine and the valve does not seal, wondering if it'll seal once there's fluid under the piston?
I don't typically iuse the rapid release valves. That clutch vents quickly enough as it is. The whole purpose of the relief hole in the drum is to prevent fluid from being forced against the outside of the 3-4 piston's bore by centrifugal force, causing the 3-4 piston to begin to apply at high RPM (remember, the input drum spins at engine speed). All it takes is a very small hole, right at the very outer edge of the bottom of the bore to relieve any centrifugal pressure and prevent any piston movement. Remember, you should be running a pretty tight 3-4 stackup, so pretty much any piston movement due to centrifugal apply will cause the 3-4 plates to drag. They won't put up with that for very long... I usually drill a .035" hole, which is large enough to relieve pressure, but small enough that the pump will easily overcome the small "leak" when the clutch is applied.
Oh, and, yes, your rapid release valve will probably seal just fine once there's fluid in there. Air will easily find it's way through places that fluid cannot go.
Thanks for the response, I've only done a couple of these.
I read about the valve somewhere and decided to try it. Probably a waste but I'll see how it works, live and learn.
When you drill the bleed hole do you plug the checkball and or the original bleed hole?
Dynamic396, I have 6 .080" friction plates and 5 .106" steels. My original backing plate is .194". I currently have .060" clearance.
I figure if I drop in a .227 backing plate, the clearance will be about .027".
Do you recommend the .035" drill mod?
I would grab one more .080" friction and six .076" 700R4 steels and stack it up with a NEW .220" OEM AC Delco apply plate and then check the clearance with your .194" backing plate and the stock .093" snap ring. You'll, most likely, be between .028" and .032" or so. If so, you're good to go, plus you now have a 7 disc 3-4 stack...
I use the .035" drill mod when the transmission is going to see consistent use at, say 5500 rpm and up. The purpose of the hole is to vent any pressure that may build up in the 3-4 piston bore due to centrifugal force. That's why I put it at the very outer edge of the bore - because that's where centrifugal force will force the oil, causing it to begin to apply the piston. If you never really reach those rpm's, the .035" hole is really unnecessary and just another leak in the circuit for the pump to deal with.
Thanks for the quick reply.
I made a little Excel sheet and was playing with different quantities and thickness.
I was wondering if .076" steels were too thin.
This is a daily driven vehicle that sees a lot of triple digits, but no real track time.
Thanks.
No, .076" steels are just fine, especially in a 7 disc stack where engagement is quick and firm. GM went to .106" steels in '94, trying to solve the 3-4 clutch burnup problems, thinking it was a heat issue within the clutch. Ultimately it was soft shift calibrations and inadequate friction surface area that were its demise. You see that in the 4L65E when GM finally redesigned the 3-4 and went to a 7 disc stack.
3-4 load release springs will always burn the 3-4s up in high RPM applications. I've NEVER put those springs back in anything...From stock transmissions to the one's we have in the 9's. They will normally also cause a 4L60E to bang the rev limiter on the 2-3 shift because the shift doesn't occur quick enough. 7 high energy frictions and 6 Kolene steels seems to work best. The Alto and the Z-Pak both suffer the same issues. The material is too thin and they warp.
Frank
Frank
I agree with MOST of what you said. I agree that 7 high energy Borgs and 6 kolenes is about as good as you're going to do in the 3-4. Every 700R4 and 4L60E that I build gets this setup...
I would be interested to hear your theory as to why the load release springs cause the 2-3 shift to bounce off the rev limiter, though... If they're in there and they're in good shape, I always put them back in. I don't lose any sleep if they're not there, but I use them if they're good.
Ever since GM brought out the concept in the late 700's, we put alot of research into what they actually do. GMs theory was to push the top and bottom pressure plates apart so the 3-4's wouldn't centifically apply at high RPMs. If you remember, the tech agency ATSG told us to leave these out of everything.
Ever pull an older 700R4 apart and find the teeth on the 3-4's worn, but the material still look good? Some looked this way after even 200,000 miles...Then, we got load release springs. The reason for GM switching to kolene steels was because of 3-4 clutch failure. They knew the springs caused the pack to apply slower, and the kolene gave it more chance to tolerate the slip the springs brought with them. How many load release spring transmissions have you pulled apart that didn't atleast have hot spotted 3-4 steels? That's because of the slower apply of the 3-4's.
This is made even worse in a high RPM application, when the 3-4's need to come on even quicker. Any delay will allow the engine to climb higher in RPM's and bang the limiter. This can be seen in many data logs that show beginning and ending shift times.
I worked at a shop for many years that was an R&D shop for many aftermarket 700/4L60E parts. If it's out there, we've tried it...LOL We had our own machine shop and made many parts that are now sold through Sonnax. I helped develop the original dual piston Sonnax O/D servo. The prototypes were used in my 700's. We started doing things with 700/4L60E's that other people thought was impossible. Mainly because we found solutions to all of their weaknessses. In the process, we proved the theories wrong on many aftermarket or "performance" parts widely available for these transmissions.
Grab the November issue of GM High Tech magazine. This is the most recent magazine we have a customers car in. The car is a 9 second, 4100# nitroused Impala SS. The 4L60E shifts at close to 7000 RPMs. It's had the same set of 3-4s in it for over 4 years...AND, he's making a 3-4 shift in the quarter mile...LOL. He launches the car in drive and makes a manual 3-4 upshift.
I'm not here to have a pissing contest or try to intentionally try to prove anybody wrong. I'm here to help. If anyone wants to know why I do or don't do something a certain way, I'll try to explain it the best I can. I hope this explanation helps people understand the problems the load release springs create, but the cause of 3-4 clutch failure go far beyond just those springs. GM designed quite a few "flaws" in these transmissions that contribute to their failure as well.
Frank
1 - 20 of 49 Posts
