I posted a while back under transmissions but no responses so I will try here.
I have just completed most of a manual 6 to auto 4 swap.
I have thus far been unable to find a shift shaft LEVER with 10mm ball that the shifter cable end snaps on to.
I have already swapped out the long shifter shaft for the short shifter shaft just need the LEVER.
I have searched and phoned almost everywhere, but no luck so far.
Discontinued but can't be that rare??
have you checked LKQ or any in person walkin junkyards at "you pull its" on any vehicle that has a 4l60E that might let you pull the lever arm off the transmission? might sound like I over simplified it but thats what i would do, when theres a will theres a way. or find a busted / blown 4l60E on ebay that has the lever arm still on it? I get 300$ for a used transmission is expensive but a car without necessary keyword necessary parts is useless .... so not running car or spend 300$ to get the car running...
