I have a P0306 code consistently being thrown and have no idea why. Since it began I have had the plugs, plug wires, an ignition coil, and fuel injectors replaced. In addition, cylinder 6 has been pressure tested. And the MAF sensor has been cleaned. No other codes are being thrown.
I will get a pending code with no FF data, then a second P0306 will be stored with FF data. 02/02. So I'll have a pending and a stored. The stored code will go away while the pending normally stays. Over and over.
I do not understand. I am looking for ideas. I appreciate any helpful information I can get.
Look for spark leakage. Mist the plug wires with some water. Run at night and look for spark leakage. Even though code is for cylinder # 6, plug wires near it could be having spark leakage and causing cyl # 6 to misfire.
Your crank or cam sensor could be having a problem. Unfortunately, only ways to 100% check the crank & cam sensor output is with an oxcilloscope or a GM tech 2 scanner. You can buy a PC based scope for around $70 on ebay, amazon,et .
What you would be looking for with scope is a well formed square wave from both crank and cam sensors. You can buy a clone tech 2 scanner on amazon for about $300.
But most any good obd 2 scanner with real time sensor data, could help you out.
Question: Can the crank or camshaft sensor cause the misfire code to zero in on one specific cylinder?
Yes, but don't run out and buy new ones. You need to test to see if cam & crank sensors have the proper square wave with no drop outs or misshapen signals. Only way to 100% check these signals is with an oscilloscope.
