My headlight lid on passenger side is flush on all corners except for where it meets the hood and fender.
It seems to be a bit lower than the fender/hood compared to the other sides of the headlight lid.
Can this be easily adjusted? I assume I just take the lid off, and find the adjustments under the lid?
Thanks!
It's been a while since I've messed with a headlight lid, but I believe the screws that hold them on have slotted attachment points so cover can be adjusted.
Thanks again cocobolo95! This was an easy fix - I just needed to slightly unloosen the upper-left portion of the headlight door frame that the panel attaches to....
Seriously....I really can't thank you enough for the MANY questions I had on this board and you pretty much had an answer for all of them!
Your very welcome. This is why I'm here. To help members with problems and to hopefully lead them to knowledge.
