One Rare Bird
1997 Formula Firebird 1LE
Pontiac Race Division made only 28 of these 1LE race version Firebirds, and only sold 14 to the public. The other 14 were kept for the factory race teams.
This one is registered with the Pontiac Owners Group, and the 1LE.net site.
It is all original, not restored. The only modifications being the original track use 3.23 Positraction rear gears were changed to 4.10 Molybdenum Alloy Positraction gears for street use, a Hypertech intake airfoil, and a FlowMaster 3” dual exhaust system were installed.
All original parts and documents were kept, including invoice and window sticker.
The computer control program was optimized by Dragon Race Engineering, and Custom Hand Painted Ghost Flames were added by “Flames by Ray”.
The 1LE Story: The 1LE’s were originally made by Pontiac Race Division
for the Canadian Cup Race Challenge. Factory modifications included:
1. An LT1 Predator series 5.7L (350 c.i.) sequential Fuel Injected Engine
with a cast Iron block and Aluminum heads, WS6 Ram Air package,
roller rockers, 4 bolt center main bearings, and a gear driven water pump.
Producing 305 bhp and 325 ft.lb torque with a 6000 rpm Red line.
These were improved by Dragon Race Engineering to 315 bhp and 340 ft.lb.
2. A Borg Warner T56 6 speed manual Transmission.
3. An Aluminum drive shaft and 4.10 Molybdenum Alloy Positraction rear end.
4. Oversized 12” Brake rotors with dual piston Aluminum calipers.
5. 275ZR40X17 Track rated Racing Tires on heat treated Alloy Mag Wheels
6. “Koni” dual adjustable Racing Shocks
7. Oversized Sway bars and Traction bars
8. All Neoprene suspension bushings
9. 10 gauges including: Oil Temperature, Oil Pressure, Water Temperature
Manifold Vacuum Pressure, Ammeter, Fuel, Speed, Tachometer,
Odometer and Lap Odometer.
10.An oversized 18 gal. gas tank with dual deep sump pickups and baffles
to eliminate sloshing and fuel starving in tight cornering, down to ½ gal.
There were no options available, no electric seats, no electric windows, as these were not Racing Equipment. Originally placing an order required supplying GM with a copy of your Track Racing Certification, but this was eventually dropped, although factory literature listed the 1LE option as
“For the serious race competitor. Not recommended for Street Use.”
The one concession for units sold to the public was an available radio.
Even with the lower 4.10 gear ratio, 6th gear @ 5682 rpm = 200 mph
This car was appraised in 2003 by AMC Classic Appraisers (International Automotive Appraisers Association Master Certified) for $21,000.00, and in the appraisers own words “That is based solely on equipment and condition and does not include any premium for its extreme rarity and collectability, as it is hard to put a price on that”.
Of course that was before Pontiac closed its doors. There will never be another Firebird.
And NOW it is for sale! This is your chance to own a piece of Automotive History!
Email: [email protected] or Call Robert at 303-252-4697. Serious inquiries only! $20,000 o.b.o.
