Northwest Indiana
$4000 OBO cash only. Clean title in hand.
LT1 5.7L V8 engine
Automatic transmission
171k miles on odometer( Not accurate. )
Entire ignition system replaced ( New ACDelco Optispark, Plug wires and spark plugs )
New ignition coil
New ignition control module
Heat & AC DO work
T-Tops do not leak
Interior is in decent shape. Moderate rips in driver side seat. No major damage
Red & Black cloth seats and door upholstery
All lights work including fog lights and 3rd brake light
Trunk release works
Power locks & windows work
Rims are currently painted black
Runs and drives great
Car is very clean for its age. I could not find any rust on the body, very very little rust on the underside
Minor dent & paintchip above the gas cap
Small tear on driver side door above the keyhole
Car has 2 12'' subs that are already wired by the previous owner. Needs a new amp
Transmission has a shift kit
Hooker cat-back exhaust
3.73 rear end gears
The gears are the reason the odometer is not accurate. Speedometer reads higher than actual speed,( 45mph reads 60 on the speedo ) thus causing the odometer to increase faster than the actual miles being traveled.
LT1 5.7L V8 engine
New ignition coil
Heat & AC DO work
T-Tops do not leak
Trunk release works
3.73 rear end gears
