Hi everybody,
does anybody have PCM diagram (PCM connector terminal ends) for 1993 LT1 Camaro?
I'm, in the process of swapping LT1/T56 from 1993 Camaro into my 1988 GTA and I use complete wiring from Camaro, but have one problem. There is a few cutted wires that I need to connect to T56, but I don't have wiring diagram :(
I need wiring diagram for T56's Skip shift solenoid, reverse lockout solenoid, back lamp switch and speed sensor switch.
Thank You all in advance.
Best regards.
If it will help you I have the 93 pcm pinouts and the pcm to component diagrams I can send you. If interested pm me with your e-mail address. I also have some other 93 stuff I can send you if you want.
Welcome to the forum.
I now have a site that you can download the entire 93 factory service manual for free. It has all the above mentioned info & everything else you need to fix a 93 camaro or firebird. www.mediafire.com/?40mfgeoe4ctti.
As a newbe, I guess you didn't notice this thread is almost 10 years old. Most of the members from that time are gone. But I'm still here.
