1 - 20 of 25 Posts
· Premium Member
I don't think I will ever get my 13 second run, 3 passes of 14.4 with a 2.1 short time. I think my transmission is about gone as well, OD doesn't work and when shifting from 1st to 2nd the car would shift into 2nd then 3rd and back to 2nd. And to top my day off my drivers side window motor broke so I couldn't put my window up, so I called it a day. Some days you get the track and some days the track get you. I hope everyone else had a good weekend.
What tires are you using?
· Premium Member
Discussion Starter · #8 ·
I'm running M/T DR's. The best time I ran in the car was a 14.0 with a 2.0 short time and that was on street tires. My next move after fixing the window so they will let me race is to rip the AOD out and go with a T5.
· Premium Member
Discussion Starter · #12 ·
Vendetta said:
a higher stall torque converter
No, it's all stock (I think the tranny is about gone). Not much done to the car. I was happy with a best of 14.0 on street tires and thought DR's would drop me into the 13's.
Here's the breakdown on the car:
1991 LX AOD 198,000 miles
4.10 gears
K&N filter (stock air box)
70mm TB
MAF
Timing bumped to 14'
Under-drive pullies
A/C, Smog pump, air silencer, front sway bar removed
Once I went with the DR's I slowed down 4 tenths, the weather has been alot hotter also.
So I don't know if it's the heat or the Dr's bogging me down some. I would guess the car is around 200 to the wheels with that many miles.
· Premium Member
Discussion Starter · #14 ·
1970judge said:
Sound like your 60' is whats eating your times. you could see HIGH 13's with yoursetup id bet. A stall ,and some suspension work will def get you there though.
Yea, I can't get the car under a 2.0 short time, not to worry I'm dumping the AOD and going with a T5
When are you going to do the tranny swap?
1 - 20 of 25 Posts
