1999 Firebird 3.8 Misfire Problem - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 3 (permalink) Old 05-29-2013, 06:02 PM Thread Starter
About a week ago I starte having misfire problems with my firebird. It came up as a bad coil so I replaced. The problem stopped for a day now I have a misfire again. Is there any tests I can do at home without spending much money?
I'm sort of a newbie mechanic, I know general terms and can fix things if pointed in the right direction.
TJ406 is offline
post #2 of 3 (permalink) Old 07-09-2013, 06:10 PM
96z
oh it happens alot with those. Im assuming your motor was a pick n pull from the graveyard, alot of those need new plugs. i would pick up a set of ngk irdiums if anything.
96z is offline
post #3 of 3 (permalink) Old 07-09-2013, 06:57 PM
Project96's Avatar
I had the same problem with my camaro. 2 coils later & an icm & it was fixed.
Sent from AutoGuide.com Free App
Red 1994 Trans Am Coupe
Red 1996 Camaro RS - T-Top, stock (Y87)
Project96 is offline
