95 camaro oil pan gasket - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 5 (permalink) Old 01-10-2013, 03:15 AM Thread Starter
Unhappy 95 camaro oil pan gasket
do anybody no a way 2 change the oil pan gasket without droping the engine
2sadboy31313 is offline
post #2 of 5 (permalink) Old 01-10-2013, 07:30 AM
You take off the motor mount bolts and lift the engine ,with a hoist or jack, high enough that you can remove the oil pan.
post #3 of 5 (permalink) Old 01-10-2013, 11:41 AM Thread Starter
so basically thts all i gota do so i dnt hve to disconect anything
post #4 of 5 (permalink) Old 01-10-2013, 12:18 PM
Yo!
R3DLT1's Avatar
Easily said then done
R3DLT1 is offline
post #5 of 5 (permalink) Old 04-17-2013, 02:13 PM
Workman's Avatar
I would loosen up your tranny mount a tad bit, Like dont take the bolt off of it, but loosen the bolt enough.
My dad has an old BMW E28 And his gasket is bad wich requires the motor to be jacked up higher then you can belive. So he asked me how to fix it. I told him the same thing coco told you. But he asked, any other way? I smiled and said well its just an old junk bmw thats never gonna be workin right, you could just put gasket sealer all the way around the lip of the oil pan lol =]
Needless to say the job is done the wrong way, but doesnt leak anymore. AND THIS THING LEAKED. BAD before and now nothing.
Dont do it the wrong way lol .
95 T/A , M6 , Lt4 hotcam , 1.6 RR, Trickflow aluminum heads, Moroso CAI, Polished Elbow, 58 MM Holley TB, 44 pound Injectors, Edelbrock RPM air gap Intake, MSD wires, MSD opti, Pacesetter LTs, Spiral Bullet, Magnaflow catback, 4.10 gears, Aluminum Driveshaft.
93 Corvette Spec Flywheel
Workman is offline
