engine wireharness - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 16 (permalink) Old 09-16-2009, 11:57 AM Thread Starter
startrek89's Avatar
engine wireharness
Its a simple question I'm going to drop an lt1 in and I don't know how to remove the engine wire harness and computer any tips or advice?
startrek89 is offline
post #2 of 16 (permalink) Old 09-16-2009, 12:07 PM
Yo!
R3DLT1's Avatar
my best advice would probably be take your time and label the wires.
R3DLT1 is offline
post #3 of 16 (permalink) Old 09-16-2009, 12:13 PM
BrdwAtti2d's Avatar
Send a message via AIM to BrdwAtti2d Send a message via Yahoo to BrdwAtti2d
The insulator boots are color coded, ok well to a point. Orange = ignition, blue = air, purple = fuel, etc. Like R3D says, labels and take pictures of where they go. If you get stuck you can go back to the pics.
Tracy
2002 L36 Firebird
1997 LT1 Firebird Formula (SOLD)
guys with stock throttle bodies have smaller orifices.
BrdwAtti2d is offline
post #4 of 16 (permalink) Old 09-16-2009, 12:13 PM Thread Starter
startrek89's Avatar
I have the wires mark but I was told to remove the w/harness for the v8's harness
post #5 of 16 (permalink) Old 09-16-2009, 12:15 PM
BrdwAtti2d's Avatar
Yea you have to swap harnesses, the V6 pcm and harness won't work.
Tracy
2002 L36 Firebird
post #6 of 16 (permalink) Old 09-16-2009, 12:24 PM Thread Starter
startrek89's Avatar
Thanks we got the w/harness out the way do you know where the computer is?
post #7 of 16 (permalink) Old 09-16-2009, 12:36 PM
BrdwAtti2d's Avatar
Tried to find a pic for you but couldn't find one. It's mounted up on the corner of the firewall on the passenger side. Trace the harness back and everything terminates there.
Tracy
2002 L36 Firebird
post #8 of 16 (permalink) Old 09-16-2009, 12:37 PM
Yo!
R3DLT1's Avatar
http://shbox.com/1/fuel_pump_prime.jpg
PCM is right here on the V8
R3DLT1 is offline
post #9 of 16 (permalink) Old 09-16-2009, 12:43 PM
BrdwAtti2d's Avatar
Lol, "seasoned", I like that. Guess that makes me spicy as hell.
Tracy
2002 L36 Firebird
post #10 of 16 (permalink) Old 09-16-2009, 02:50 PM
10 Second Opti Club
sweetbmxrider's Avatar
you have to swap out the body harness under the dash along with the instrument cluster, rad, rad fans, and possibly other crap depending on year to year. trans and driveshaft are different. rear should be swapped as well for posi.
sweetbmxrider is offline
post #11 of 16 (permalink) Old 09-21-2009, 02:11 AM
93-95 harness's should be the same. As long as the harness and computer used had the same options as the car it's going into. Like cruise,traction control and such. Then you got 96-97.
And the driveshaft should be the same between a v6 and v8. I don't see why it wouldn't be. The trans is mounted in the same spot along with the tourqe arm.
Radiator and fans should also be the same between a v6 and v8. Clusters don't need swapped either. Unless you want the higher speedo. Though the speedo might be off. Not sure on that one.
As for the rear. If i'm not mistaken. Didn't a certain package come with rear disk brakes and limited slip in the v6? We don't have posi either it's limited slip. v6's most came with a open diff.
2fast4u88 is offline
post #12 of 16 (permalink) Old 09-21-2009, 10:49 AM
10 Second Opti Club
early f-body v6 driveshafts are 2 piece. radiator is smaller and is a single fan setup. you will most certainly have cluster issues but seems like anything i write has been 2nd guessed. there were v6's with disc as an option, think its y87. dual exhaust and whatnot.
springs also need to be changed along with fuel pump. fuel lines will have issues reaching the lt1 rail. theres alot of bs that goes along with it. www.camarov6.com would be a good source for more info.
post #13 of 16 (permalink) Old 09-21-2009, 01:34 PM
Project96's Avatar
It is the Y87 package. It came with four wheel disc brakes, dual exhaust, & the rear end & the steering ratio were the same as the Z28/TA. The performance handeling package is what they called it. The transmission on the v6 is flat at the top of the bell housing instead of pointed like the v8 & drive shaft is also a 2 piece on the v6 & single piece on the v8 cars. Not sure about 98 & beyond though. My v6 also has dual rad fan as well. Although I believe one is for the A/C. The v6 & v8 engine harness will be different, but I'm not sure about the body harness. Fuel lines are different, not sure about pump. I'm not sure about the computer which by the way in tucked next to the passanger side hood hinge. Didn't traction control come out in '98 & later cars?
Red 1994 Trans Am Coupe
Red 1996 Camaro RS - T-Top, stock (Y87)
Project96 is offline
post #14 of 16 (permalink) Old 09-21-2009, 02:51 PM
10 Second Opti Club
traction control was available pre 98. my 95 3.4L is a single cooling fan setup.
post #15 of 16 (permalink) Old 09-21-2009, 02:59 PM
BrdwAtti2d's Avatar
Here's a list of all that has to be swapped. This thread seems to have quite a bit of misinformation.
http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
Tracy
2002 L36 Firebird
