V6 TO V8 SWAP - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 17 (permalink) Old 06-29-2009, 06:48 PM Thread Starter
keenan's Avatar
V6 TO V8 SWAP
What all needs to be done to swap from a v6 to v8 wiring harness , i know how about the k member does it need to be swapped also.
Swapping transmission also.
Krazy Kajun 95 camaro 383 LTI A4 ,58mm Edelbrock TB,3.73gears,Descreened MAF, Trans go shift kit,4000 stall,b&m cooler,K&Ncai,Tune from Trifecta Performance , LT Headers,CSR water pump.Stage 3 P&P Heads ,Comp. Cams XFI 292 ,1.6 RR's.
keenan is offline
post #2 of 17 (permalink) Old 06-29-2009, 07:01 PM
Less than 8 cylinder Moderator
GTP231's Avatar
Send a message via Yahoo to GTP231
What V6 to what V8. If its a LSx you'll definitely need a K memember but not sure on LTxs
Mr. Black Angus
01 PT Cruiser (beater for now)
03 GTP Stock I swear
13.464 @ 103.51 mph spinning a lil Totaled 9/25/2010
LSx> L67> Cross Fire> LTx
God said, let there be light, and the optispark was born...and he saw that it was bad.
Lt1's suck.
GTP231 is offline
post #3 of 17 (permalink) Old 06-29-2009, 08:58 PM Thread Starter
keenan's Avatar
Yeah sorry it's LTX
keenan is offline
post #4 of 17 (permalink) Old 06-29-2009, 10:24 PM
GTP231's Avatar
Mounts might be the same and not need a front end. Not sure about the LTx stuff
Mr. Black Angus
Lt1's suck.
GTP231 is offline
post #5 of 17 (permalink) Old 08-27-2009, 02:56 PM
ACE
anyone know
i changed a 3.4 L for 5.7 L lt1 into a 95 camaro from a 95 firebird rage top RIP 07/22/08. But anyway's i used the computer land harness allso had to fab the driver side motor mount an i used a three speed trany 350 turbo with a shortend drive shaft.Ran great at first but now it has a splutter to it and i think it's the fuel pump or the mas IDK
ACE is offline
post #6 of 17 (permalink) Old 08-27-2009, 09:24 PM
startrek89's Avatar
For f-bodys an ltx get the computer w/harness and rear gear changed I'm putting an lt1 in my v6 firebird everything bolts right up or if you want more get a real grandnational motor/trans and w.harness you might need a computer too if you do that you would have one of the fastest f-bodys around
startrek89 is offline
post #7 of 17 (permalink) Old 08-27-2009, 10:25 PM
ACE
DO you know what exactly needs changed? on the DLC
ACE is offline
post #8 of 17 (permalink) Old 08-28-2009, 10:34 PM
ACE
Well i changed the MAS and no change wat so ever and thanks for the tip on the DLC Much appreciated oh and all so where can i get a service book and how much is it if you know
ACE is offline
post #9 of 17 (permalink) Old 08-28-2009, 10:41 PM
startrek89's Avatar
You can get a service book from an autozone/murrays they should cost around 19.99-24.99 make sure you get the one for your year they cover almost everthing you need to know
post #10 of 17 (permalink) Old 09-01-2009, 10:28 PM
ACE
startrek89
Those books dont have what i need ALLDATA
95 camaro all stock + A 69 under construction with a 327 auto with a posi trac and duel exhaust
ACE is offline
post #11 of 17 (permalink) Old 01-15-2010, 01:07 AM
Did you have to change the fuel pump for it to start?
TheReginator is offline
post #12 of 17 (permalink) Old 09-10-2012, 03:15 PM
camaro1991's Avatar
Unhappy v6 to v8 need help please
i also have done a v6 to v8 swap and i am stuck im new at this fourm and i have no idea how all of this works. but i swapped my 96 3.8 to a 94 lt1 and i swapped everything i could think of. motor, k member, wirering harness, transmition, drive shaft, computer, gauges, and i have everything hooked up right i would think. well here is my problem. after i got the motor in and everything together i put the key in and the fuel pump didnt cut on and the distributor isnt getting fire. i was told its the chip in my key that i needed to get the right resistance for the new computer so i did that and now nothing at all happens except my security light comes on and my car doesnt do anything ive called the dealership and they have no clue as what im talking about. and i am at the point where im frustrated and idk what else to do or try. do i need a new bcm? a new tdm? what i have no clue someone please help me. any advise will be great. and the lt1 came3 out of another camaro as well.
camaro1991 is offline
post #13 of 17 (permalink) Old 09-11-2012, 08:48 AM
You have to change you're wiring in the 3 connector harness that comes off of the CPU. Get someone to get you a diagram of those connectors and just splice them together. I had the same exact problem. The sputtering may be the transmission mount, My car was jerking whenever I laid into it out of a turn, it may just be the fuel pump though but I was having the same problem so make sure thats not it, but you will eventually have to change the fuel pump the LPH isn't high enough for the LT1 but the fuel pressure is so it'll work for starting and light driving but once you try to drive it hard you'll have problems. What part of GA?
post #14 of 17 (permalink) Old 09-11-2012, 11:19 AM
10 Second Opti Club
sweetbmxrider's Avatar
You still have vats issues. Check out shbox.com and read up on vats.
sweetbmxrider is offline
post #15 of 17 (permalink) Old 09-11-2012, 03:55 PM
I don't think it's VATS you swapped the engine harness not the body harness, you HAVE to get the diagrams for the harnesses and swap the wires you need to...it's wiring
