Just picked up a 98 firebird with a running issue give me some ideas please - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 16 (permalink) Old 05-23-2009, 06:46 PM Thread Starter
99hawk's Avatar
the car is a 1998 red 3800 firebird that seems to have a fuel problem. the previous owner said it ran fine when he parked it 5 or 6 months ago. if you put the gas pedal to wot (the floor) it will run (like crap) at very low rpms for a moment or two. you can here the fuel pump cycle when you turn the key. any ideas. car is automatic also thanks
99hawk is offline
post #2 of 16 (permalink) Old 05-23-2009, 08:14 PM
93v8clone's Avatar
prolly needs a full tune up ,i-e fuel filter,air filt, plugs ,wires ,pcv ........they were also good for takin out a ign module from time to time also but id start at the tune up from what you are tellin us
94 z28 ,a4,358 ci, pacesetter long tubes ,holley 52mmt/b,!cat!air!egr n/x hitman wet kit 3.42 gears moroso c.a.i vortech intake elbow,edge 3.5 k converter full rear spohn susp .. cc503.pro mag 1.6 rockers 918springs dyno tune
93v8clone is offline
post #3 of 16 (permalink) Old 05-24-2009, 12:16 AM Thread Starter
99hawk's Avatar
i know changing plugs is like changing engine in the 3800. my brother had a green 98 fully loaded took me a week to change the plugs. found out your not to reuse the aluminum covers on the engine end of the wire.
99hawk is offline
post #4 of 16 (permalink) Old 05-24-2009, 12:21 AM Thread Starter
99hawk's Avatar
im on the fence on weather i will part the car or fix-r-up for sale or the wife. (the wife like the car)
99 FIREHAWK # 104
94 25TH ANNIVERSARY
80 BLACK TRANS AM T-TOP
79 BLACK TRANS AM T-TOP 4 SPEED
71 FORMULA 350
"BEER, THE CAUSE OF AND SOLUTION TO all of lifes problems" -Homer Simpson
99hawk is offline
post #5 of 16 (permalink) Old 05-24-2009, 11:45 AM
Originally Posted by CKJ View Post
Dang, i never knew it was such a difference between the 3.4's and 3.8's when it comes to that aspect. If the plug boots would have cooperated and not have been stuck to the plugs I could have easily changed them in 15-20 minutes in my 3.4.
Guess that means mine won't get changed for a long long time....
Jessica
CKJ's !GFDM
Freebird is offline
post #6 of 16 (permalink) Old 05-24-2009, 12:19 PM
Less than 8 cylinder Moderator
GTP231's Avatar
Send a message via Yahoo to GTP231
I've never had a fun time doing the first plug change on any 3800. Other than the boot not coming off easily plug changes aren't that bad though on the F Bodies
Mr. Black Angus
01 PT Cruiser (beater for now)
03 GTP Stock I swear
13.464 @ 103.51 mph spinning a lil Totaled 9/25/2010
LSx> L67> Cross Fire> LTx
God said, let there be light, and the optispark was born...and he saw that it was bad.
Lt1's suck.
GTP231 is offline
post #7 of 16 (permalink) Old 05-24-2009, 01:10 PM
GTP231's Avatar
I mean it was literally bonded/melted to the plug. I had to take a long prybar and break the porcelain off the plug to get to the hex part of the spark plug
Mine wasn't quite that bad in 04 when I changed them for the pulley swap. I was worried I was gonna lose a few wires though
My Taylors have been fine since I got the boot protectors.
Mr. Black Angus
Lt1's suck.
GTP231 is offline
post #8 of 16 (permalink) Old 05-26-2009, 11:32 PM Thread Starter
99hawk's Avatar
changed the plugs out and still the same. (wasn't as bad as it was on my bro's car) maybe a sensor went bad. its seems to have fuel pressure. (anyone know how much fuel pressure a 3.8l engine should be getting??) I'm going to get a fuel pressure gauge this week. could i hook up a obd2 scanner and check it out without it running??
99 FIREHAWK # 104
94 25TH ANNIVERSARY
71 FORMULA 350
99hawk is offline
post #9 of 16 (permalink) Old 05-27-2009, 12:21 AM
GTP231's Avatar
Can't see pressure on a scan tool.
Mr. Black Angus
Lt1's suck.
GTP231 is offline
post #10 of 16 (permalink) Old 05-27-2009, 08:04 PM Thread Starter
99hawk's Avatar
im quite aware of this, im going to get a pressure gauge set for my shop plus a scan tool.
99 FIREHAWK # 104
94 25TH ANNIVERSARY
71 FORMULA 350
99hawk is offline
post #11 of 16 (permalink) Old 05-27-2009, 08:56 PM
GTP231's Avatar
Ok your post seemed to say otherwise.
Mr. Black Angus
Lt1's suck.
GTP231 is offline
post #12 of 16 (permalink) Old 05-27-2009, 10:04 PM Thread Starter
99hawk's Avatar
my dad said to just drop a Pontiac 400 in it and call it a firebird. (he old school Pontiac)
99 FIREHAWK # 104
94 25TH ANNIVERSARY
71 FORMULA 350
99hawk is offline
post #13 of 16 (permalink) Old 05-28-2009, 02:12 AM
GTP231's Avatar
That's always an option
Mr. Black Angus
Lt1's suck.
GTP231 is offline
