Urgent car starts ONCE after flash - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 4 (permalink) Old 12-10-2017, 06:56 PM Thread Starter
kris72079's Avatar
Tracing a big pain in my a**! Using EEHack I flash a .bin file into my pcm and the car starts, runs, etc as you'd expect it should. Turn key off and then back to start again and it makes ZERO attempt to restart. Reflash SAME bin file back into the pcm and it restarts and runs as it should. Shut it off, and we'll I bet you can imagine what happens.
Scanning with scan94/95 reveals noteworthy items...
WHILE RUNNING:
inj pulse - ~3.85ms
IAC steps - 16
command idle - 800rpm
actual idle - 800rpm (+/-5)
AFTER SHUTDOWN AND RESTART
inj pulse - ~48.5ms
IAC steps - ~140
inj fault this run* set 1
No DTC set (silent or CEL)
ANY HELP WOULD BE GREATLY APPRECIATED!
1996 Pontiac Firebird, 396 ltx, 24x, forged eagle crank, 6" compstar rods, 5cc forged pistons, LE custom billet 263/271 .688/.688 108 LSA, LE ported AFRs, Pacesetter LTs, 200hp Nirtous Outlet plate, 4L80E, Moser 9" w/4.30 & trutrac
kris72079 is offline
post #2 of 4 (permalink) Old 12-10-2017, 07:27 PM
in eehack, is it flashing both e-side and t-side?
ensure both e-side and t-side are checked, uncheck 'skip unused regions' and 'insert patches' just to see if that helps
... although it shouldn't
post #3 of 4 (permalink) Old 12-10-2017, 09:24 PM Thread Starter
kris72079's Avatar
Steveo, I was hoping you'd reply. both e-side and t-side are loading. I just reaccomplished a load with skip unused regions and insert patches unchecked. No change. After it successfully starts and I shut it off, I get the "inj flt this run*" error message in scan94/95. Do you know what triggers this? Its after every cycle, then it wont restart. I spoke to GaryDoug and he said he is just the program writer...
post #4 of 4 (permalink) Old 12-11-2017, 10:06 PM
