rough cold start and idle. - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 4 (permalink) Old 07-06-2019, 08:04 PM Thread Starter
Hello everyone, new to the forum! I own a 1994 z28 Camaro. I was hoping y'all could help provide some answers for the problem I'm having with the old girl. When I start my car cold it struggles to fire sometimes cranking for almost thirty seconds before firing or even the occasional backfire that terrorizes my neighborhood. Once the car is running it idles poorly smelling of fuel, misses, and bogs under heavy throttle. But once the engine warms up and the car gets up to operating temp it runs perfectly fine, and when I shut it off after the engines warmed up, it will start right up with no hesitation. Can anyone tell me what is wrong? Bad opti? I was told maybe the coolant temp sensor on the water pump? Some insights would be greatly apprecitated!
ryanstollz28 is offline
post #2 of 4 (permalink) Old 07-06-2019, 08:44 PM
Sounds like fuel pump might be going. I had very similar symptoms when fuel pump was getting ready to fail. I had to prime engine to start car by turning key from off to on several times before I would start the engine. Almost as if to pressurize the fuel line.
See if that helps.
Sent from my iPhone using Tapatalk Pro
Mark611 is offline
post #3 of 4 (permalink) Old 07-07-2019, 07:18 AM
Also, I did have the coolant temp sensor go bad. It was very corroded when I yanked pig tail off. Replaced pigtail and sensor and car fired right up. I remember a lot of black smoke and backfiring when it was bad.
Mark611 is offline
post #4 of 4 (permalink) Old 07-07-2019, 07:25 AM
If you suspect fuel pump problems, get a fuel pressure tester and attach it to valve on fuel rail. Do key on prime, pressure should be about 43 psi.
Since car starts & runs well when warm, I suspect fuel pump is not the problem. You need to put your car on an obd 1 scanner. One that not only does codes, but also will show running sensor data. First check for codes as the 4 ignition biggies don't light the check engine light. And on a 94, you can't connect the aldl terminals to read codes like on the 93 & older cars.
After reading codes, I suggest doing a running sensor data scan. See what the sensor data is telling you. CTS will cause problems when it's bad. But they usually don't magically fix themselves when engine warms up. If you haven't a clue to what sensor data means, PM me with your email address. I'll send you the PDF file " scanner readings and what they mean".
Get the 94 service manual at the following link. It has a driveability & emissions section. It will have troubleshooting, code explanations, wiring diagrams, etc. My Files
If you have codes 16 & 36, you have opti problems.
