95 lt1 t56 clutch bleed?????? - Page 2 - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #16 of 17 (permalink) Old 05-18-2011, 10:22 AM Thread Starter
lt1 rice eater!'s Avatar
i did a ton of research and there is a gm methos involving loosining the master cylinder but the best way is to pull it hold it rightside ip and pump it with the cap off the resevoir they both work
95 trans am; shade tree built rear mount. Under construction again
71 camaro;heads,cam,stall,gear,lots of nitrous
,01 frontier; dd
lt1 rice eater! is offline
post #17 of 17 (permalink) Old 11-21-2019, 10:12 AM
I have tried all the ways listed and no luck ain’t getting much pressure. I took the whole system off bench bleed it. All is brand new from slave cylinder the hydraulic line and the master cylinder all new. I have done everything no luck don’t know what else to do. Appreciate any other ideas if anyone has had this problem
Joshktmfo50 is offline
