random mis fire - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 10 (permalink) Old 04-25-2007, 01:17 PM Thread Starter
random mis fire
Ever since I installed my AS&M mid length headers I've gotten code 300 random miss fire. Spark Plugs are brand new. Plug wires are all secured on the plugs. I have no idea what could be causing this. My back two 02's are still not plugged in because I'm waiting for my 02 simulators. Could that cause the random miss fire? Please help, car is a 97 m6 with 78k on it.
-Dave
z28Dave is offline
post #2 of 10 (permalink) Old 04-25-2007, 05:50 PM
having your 02s not plugged in will cause backfire.....dont run anymore until you get that taken care of
Just a little lt1.....020 over speed pro pistons,comp custom cam,comp push rods,comp 1.6 rrs,and lifters,cnc stock ported heads,Walbro 255,edelbrock ported air gap intake,58mm t/b,pacesetter Lts,Summit 2.5 x-pipe with dynomax bullets,march underdrive pulleys,gm opti,msd cap and rotor,Msd 6AL,Moore 10mm race wires,SLP line lock,SLP fan switch,aluminum D/S,Built 4l60e,TCI 3,000 stall,B&M trans cooler3.73s,Edelbrock adjustable torque arm and Panard bar.more to come over the winter
my1994z28 is offline
post #3 of 10 (permalink) Old 04-25-2007, 06:03 PM
03slowZ06's Avatar
No the rear o2's will not cause it. They have nothing to do with timing. Check for burnt wires.
u can do it
03slowZ06 is offline
post #4 of 10 (permalink) Old 04-25-2007, 11:35 PM Thread Starter
no wires are burnt. Could the two front 02's be fouled out?
-Dave
z28Dave is offline
post #5 of 10 (permalink) Old 04-25-2007, 11:38 PM
03slowZ06's Avatar
Its possible but you would usually get a DTC if they were completely shot. Let me ponder this.
u can do it
post #6 of 10 (permalink) Old 04-25-2007, 11:40 PM
03slowZ06's Avatar
What wires do you have on there? Go start it and let it warm up. Open the hood in the dark with it idling and see if you can see any wires arching.
u can do it
post #7 of 10 (permalink) Old 04-26-2007, 12:48 AM
It's quite possible that you could have a bad wire out of the box too... I've had that happen before... Took me forever to figure that out. If you can get ahold of a laser thermometer, try each header primary and when you find one colder than the rest, you've narrowed it down to one cylider. You should also check your injectors, that will cause a misfire too, although it won't have anything to do with the headers...
White96Z28 is offline
post #8 of 10 (permalink) Old 04-26-2007, 01:17 AM Thread Starter
Whats a bid wire?
z28Dave is offline
post #9 of 10 (permalink) Old 04-26-2007, 01:28 AM
You get a bid wire when you don't proofread your posts....
post #10 of 10 (permalink) Old 04-27-2007, 01:44 AM Thread Starter
Well I checked the plugs at night and one was arcing pretty bad on the drivers side. I ordered some Accel plug wires. I have to route them over the headers and not the factory routing due to the mid length headers correct?
-Dave
z28Dave is offline
