questions about exhaust - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 5 (permalink) Old 04-22-2007, 10:21 PM Thread Starter
i dropped my engine today and was wondering if i make my own exhaust such as before the cat were the to pipes goto one into the car i was gona cut this into 2 pipes then run my own pieing down to an flomaster 50 on each side would this be ok??
pimp1913 is offline
post #2 of 5 (permalink) Old 04-23-2007, 11:02 PM
Send a message via AIM to NXSLT1
Are you talking about duals dumped before the axle?? Not sure how big that muffler is but most people with dumped duals go with some sort of bullet muffler then turn it down towards the ground right before the rear axle.
If yer trying to run it all the way out the back you'll have a lil trouble on the driver side going over the axle, it's a tight fit between the axle and that brace. I think somebody sales a modifed brace that will let you get thru there with the pipe. I've also seem people run both pipe down the passenger side where the stock pipe goes thru and then run back over to the driver side with one.
96 Trans Am M6: 52MM TB, LT's, true duals over the axle with Hooker Aerochamber mufflers, Granatelli LCA's and Panhard rod, SLP shifter, 9" with 4.11, Mickey ET streets......oh yeah, a roots blower that fits under the hood
currently working on roots blower kits for the F-Body, stay tuned..........
http://s12.photobucket.com/albums/a2...nt=exhaust.flv
NXSLT1 is offline
post #3 of 5 (permalink) Old 04-23-2007, 11:06 PM Thread Starter
would that sound good or crappy? im going for that hear me roaring from a mile away
pimp1913 is offline
post #4 of 5 (permalink) Old 04-23-2007, 11:09 PM Thread Starter
nx could you show me wee i can find a bullet and how do i gutt my cat?
pimp1913 is offline
post #5 of 5 (permalink) Old 04-23-2007, 11:24 PM
If loud is what you want then dumped duals are for you. Go to summitracing.com and search for bullet mufflers. Unless you have to do emissions testing just leaves the cats off.
NXSLT1 is offline
