cam setup - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 22 (permalink) Old 11-26-2006, 10:51 PM Thread Starter
cam setup
1995 trans am
Pacesetter Long Tubes
Hooker Cat back
QTP electric cut out
moroso cai
m6
Hello i am new to this forum but have been on ls1tech for quite some time now, they dont seem to pay too much attention to the lt1 guys so i figured id come and give you guys a try
I am looking for a cam for my car which is a DD. I want something streetable,passes smog, good power, and sounds good.
I think i have it narrowed down to the lt4 hotcam and the cc305.
Both cams seem to be around the same:
lt4 = 218/228 112
cc305 = 220/230 114
Not to sure what i want yet...
My other question is what is everything i would need as far as the rest of the installation goes?
Roller Rockers?
Springs?
Retainers?
Push Rods?
Timing Chain?
Water Pump?
Oil pump?
Gaskets?
Please let me know what is necessary and what is not, thanks!
red95lt1 is offline
post #2 of 22 (permalink) Old 11-27-2006, 12:25 AM
Grims's Avatar
Welcome to the forum.
You will need springs, which ones depends on the cam you decide to go with. hardened pushrods are also a good idea. A timing chain isn't a must...but it's a good idea to change it out while you're in there. Stock water pump can be used, Stock Oil pump is fine.
Yes, it's the opti.
96 6m Black Trans Am T-Top
Mods: Classified
Grims is offline
post #3 of 22 (permalink) Old 11-27-2006, 07:35 AM
You might try comp cams XFI line. I had part number 07-467-8 in my car with a tuned computer and it idled like stock. Also i have the vavle springs for that cam i'll take $100 shipped for them. They have never been used. I went with a different set up so i didn't need them send me a PM if you are interested. I think i paid $150 for them.
Hugger Orange 1995 Trans Am
Sherwood Green 1970 Oldsmobile 442
sleepyTA is offline
post #4 of 22 (permalink) Old 11-27-2006, 08:08 AM
CustomSSI's Avatar
Send a message via AIM to CustomSSI
Roller Rockers? Not necissary but while your there you may want to do them.
Springs? Yes. Which ones and price will vary on what cam you go with..
Retainers? Same As Above..
Push Rods? Yes some comp hardened pushrods would be a good choice..
Timing Chain? No but while your there is added safety...
Water Pump? No.. Once again you could go with a CSR and make a couple extra HP
Oil pump? No...
Gaskets? You'll need all gaskets to do teh cam swap..
If you interested in a complete package let us know and we can hook you up with a good deal :-D
Thanks
Josh
Custom Speed Sound & Image
www.CustomSSI.com
Questions? Price Quotes? Comment? Contact Us..
1-888-240-3715 / [email protected] / AIM - CustomSSI1
CustomSSI is offline
post #5 of 22 (permalink) Old 11-27-2006, 01:49 PM Thread Starter
well i might go with the lt4 hotcam kit which comes with all that. BUT i am kind of leaning towards the cc503 which i would need all that stuff, so let me know what you are thinking price wise and we can talk. thanks for all the help guys!
red95lt1 is offline
post #6 of 22 (permalink) Old 11-27-2006, 02:47 PM
CustomSSI's Avatar
red95l1 - PM Sent :-D
www.CustomSSI.com
post #7 of 22 (permalink) Old 11-27-2006, 03:30 PM Thread Starter
pm replied thanks!
red95lt1 is offline
post #8 of 22 (permalink) Old 11-28-2006, 09:43 PM
94formulac's Avatar
just curios which one did you decide on.
94 formula, magna flow cat back, cai
strut brace, eagle alloys, mt pacesetters, cc304, beehive springs, ngk plugs
94formulac is offline
post #9 of 22 (permalink) Old 11-28-2006, 11:50 PM
sam95transam's Avatar
Send a message via AIM to sam95transam
If you havent decided on which cam to choose, consider cc305 with a 112 lsa instead of a 114 lsa. I went that route about 2 months ago, and changed out my whole valvetrain and I absolutely love it. you can get that cam from thunder racing. this cam is a good dd/budget cam based on my situtation because i've noticed descent gains throughout the rpm range, hasnt effected my drivability at all, and i love the sound of the 112 lsa (even though that shouldnt be the reason you choose a cam). also, if you are on a budget, you dont technically have to have it tuned right away for it to run. even though it is recommended. just my .02
sam95transam is offline
post #10 of 22 (permalink) Old 11-29-2006, 01:35 AM Thread Starter
definitely going with the cc305. not sure if im going 112 or 114. biggest thing is passing emissions. would the 112 pass the sniffer test?
also do you have a sound clip or can you get one for me? thanks..looking for a clip of that cam with similar mods.
red95lt1 is offline
post #11 of 22 (permalink) Old 11-29-2006, 06:59 AM
Im pretty sure that with tuning it will pass emissions. esp since there are other cams that can be made to pass that are bigger ie gm 847.
http://www.youtube.com/v/_tdG0HhOIoA
http://www.youtube.com/v/06u0OQP4tac
http://www.youtube.com/v/T7fQSjDaLb0
here are a couple of vids my dad took for me. i am in college right now, and i will get some better vids and post them when i go back home this weekend. I basically have the same mods you do, except I have a corsa cat-back. i dont think these vids do it justice because it sounds a bit high pitched in the clips, but in life it has a much deeper tone.
post #12 of 22 (permalink) Old 11-29-2006, 08:05 AM
I'm watching you....
BLK WS6's Avatar
Thanks
Josh
pm sent
BLK WS6 is offline
post #13 of 22 (permalink) Old 11-29-2006, 12:52 PM Thread Starter
sam95transam -
thanks for the info and vids. car sounds good. real lopey. not sure if i want it that lopey or not. is it hard to drive in traffic and whatnot? sounds REALLY Good tho!
red95lt1 is offline
post #14 of 22 (permalink) Old 11-29-2006, 01:28 PM
nah, its not really any different than before. obviously the brakes are quite what they used to be, but youll loose some with any aftermarket cam. thanks for the compliments though
post #15 of 22 (permalink) Old 11-29-2006, 01:42 PM Thread Starter
can you tell me what else you used for the install as far as rockers,springs,pushrods,timing chain/sprocket, etc...
red95lt1 is offline
