Urgent mysterious oil leak causing engine to miss - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 6 (permalink) Old 09-02-2009, 03:24 PM Thread Starter
so put some lt's on then OTVC. rewired my o2's with extensions and sodered then heatshrinked them together. wrapped the wires up in electrical tape. here's the problem.... i have the o2 wire mounted to the two bolts on the tc sheild. there is oil coming off the back of the engine somewhere causing oil to leak down the top of the trannsmission and onto the o2 wire on the drivers side..i can see drops of oil on the o2 sensor. this o2 sensor is causing my driver side plugs to burn up. i can't put the o2 wire any where else so i'm stuck to having it hooked up to the tc sheild.
possible leaking points...
1. valve cover- not leaking
2. oil sender unit- nope
3. intake manifold-nope
4. cylinder head- nope
any ideas of where it's coming from?
i'm thinking about duct taping my while driver side o2 setup so oil just rns down and off the duct tape.
any ideas?!?!
mrp82391 is offline
post #2 of 6 (permalink) Old 09-02-2009, 03:27 PM
Pull the TC cover, and check if the oil is coming from that area.
Could possibly be the rear main seal leaking.
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
post #3 of 6 (permalink) Old 09-02-2009, 03:29 PM
rear main, pan gasket, dipstick tube
94 formy a4, solomons tune for stuff ive done ! http://www.youtube.com/watch?v=2auIR-B0tvY
Originally Posted by Hughges View Post
2+2 does not= chair.
laux06 is offline
post #4 of 6 (permalink) Old 09-02-2009, 03:32 PM
ProjektNitemare13's Avatar
Also, oil dripping on the wires or even the unit itself shouldn't cause an erratic reading. especially not one so severe it starts burning up plugs. sounds more like there is something else going on with the connection than some oil being on the wires.
ProjektNitemare13 is offline
post #5 of 6 (permalink) Old 09-02-2009, 04:22 PM
you should never modify the wire on the o2 itself - did you extend the o2 wire or the harness wire?
post #6 of 6 (permalink) Old 09-02-2009, 04:53 PM Thread Starter
not the harness wire, the o2 wire...i spliced the wires and connected the four wires in the order they came off.
also oil running down the wires onto the or sensor could cause the o2 sensor to fail which leads to my driver's side plugs getting burned up..correct?
mrp82391 is offline
