96 Trans Am " small mis when warmed up " ? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 15 (permalink) Old 01-23-2008, 08:13 PM Thread Starter
Exclamation 96 Trans Am " small mis when warmed up " ?
when the veh. is warmed up and i am driving if down the road it will have a little mis . has a 383 stroked motor 58mm bbk full headers to magna exhaust,ram air CAI 3.73 rear built auto trans with 2800 stall and MSD box . i heard it could possibly be a multi spark box ? i am pretty sure people have had this happen please . email me if you possibly know the fix !
[email protected]
THANKS
saleentrooper is offline
post #2 of 15 (permalink) Old 01-23-2008, 08:33 PM
CKJ
Guest
Posts: n/a
You'll really have to be a little more specific. If your driving down the road and come up on a slight hill and your car didn't downshift and your RPM's are around the 1200-1500 mark and it aquired a slight miss/hestistation then i'd say change your fuel filter first as a possible fix and a preventative maintence. Also pull a few plugs to see how they look. Also plug wires is another possiblity.
post #3 of 15 (permalink) Old 01-23-2008, 09:06 PM
Check your spark plugs and gap?
red_z28 is offline
post #4 of 15 (permalink) Old 01-24-2008, 03:38 AM
mtperformance's Avatar
How old are your O2's?
mtperformance is offline
post #5 of 15 (permalink) Old 01-24-2008, 08:06 AM Thread Starter
o2
kind of old , i think i will replay them and go with a MSD opti and see what happens
post #6 of 15 (permalink) Old 01-24-2008, 08:32 AM
Grims's Avatar
500 here 500 there and pretty soon we're talkin serious money
Yes, it's the opti.
96 6m Black Trans Am T-Top
Mods: Classified
Grims is offline
post #7 of 15 (permalink) Old 01-24-2008, 08:58 PM
CKJ
Guest
Posts: n/a
wow you just jumped from the frying pan into hell I'd say do some smaller simplier things that can cause a miss before forking out 500 on a MSD opti. Its probably just a clogged fuel filter, wire or plug.
post #8 of 15 (permalink) Old 01-24-2008, 09:34 PM
Grims's Avatar
Shh, I wanna see his reaction when he replaces it with 500 dollars of sweat and blood, only to still have a miss! This is better than Survivor!
Yes, it's the opti.
Mods: Classified
Grims is offline
post #9 of 15 (permalink) Old 01-24-2008, 09:51 PM
Guest
why do people always jump to replace the most expensive part of the ignition when it could be the $4 spark plug.
MTBSully is offline
post #10 of 15 (permalink) Old 01-25-2008, 08:35 AM
Grims's Avatar
Because when it comes to changing plugs, or changing the opti...price is no longer a factor and people start shoving money down the throttle body at WOT in fear.
Yes, it's the opti.
Mods: Classified
Grims is offline
post #11 of 15 (permalink) Old 01-26-2008, 11:47 AM
tunnel vision cant c the whole picture/lack of knowledge/misinformed.... #1 excuse w/ LT motors b da bad opti mon.
heavymetalpornstarZ28 is offline
post #12 of 15 (permalink) Old 01-26-2008, 05:40 PM Thread Starter
its was the opti
i has my mechanic look at the dist. and he replaced it with the opti . he did check all the spark plugs and wires to make sure everything was still in order . lol
post #13 of 15 (permalink) Old 01-26-2008, 07:28 PM
LearJet's Avatar
Wow, it was the opti!
1997 Z28- Pacesetter LT's w/ ORY , Magnaflow catback, CC503 camshaft, 1.6 Comp ProMags, Comp 918 beehive springs, CNC ported and polished stock heads, K&N FIPK CAI, Level 3 4L60E, 9.5 inch 3000 stall, Motive 3.73's, !Cats, !EGR, !A.I.R., LT4 KM. Tuned by Brian at pcmforless.com.
LearJet is offline
post #14 of 15 (permalink) Old 01-26-2008, 09:13 PM
Honestly, changing an opti to me is easier then doing a plug wire change on a LT1. Passenger side is doing a plug wire change is BRUTAL.
philosophico is offline
post #15 of 15 (permalink) Old 01-26-2008, 11:05 PM
CKJ
Guest
Posts: n/a
So was it indeed the opti....? You never really said if it was or wasn't.
