Lt1 tapping sound - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 21 (permalink) Old 09-28-2016, 07:49 PM Thread Starter
Lt1 tapping sound
Okay so I got this engine used, it had issues but when installing it my mechanic said it had good compression etc.
It has 1.6rr and long tube headers.
I've attached a link to a video where you can hear the sound. It only seems to do it when warm.
https://youtu.be/VIdaLUV9dgg
Thomas Terry is offline
post #2 of 21 (permalink) Old 09-28-2016, 08:55 PM
Workman's Avatar
Sounds like Mine did when it spun a rod bearing.
I hope it isn't that friend. Hold good oil pressure ? Even after warmed up ?
Workman is offline
post #3 of 21 (permalink) Old 09-28-2016, 09:22 PM Thread Starter
Yes it holds about 50psi at idle and about 60psi while driving.
post #4 of 21 (permalink) Old 09-29-2016, 09:44 AM
Some video/audio with a few revs in it might be more helpful. Sounds more like in the valve train. Might want to pull the valve covers off and observe.
post #5 of 21 (permalink) Old 09-29-2016, 11:31 AM
50 PSI at idle - hot? Holy crap. My engine is new with about 1000 miles on it, built by Karl Ellwein, and once its hot I get about 35 psi at idle while in gear (800 RPM). Cold, is another matter.
Get a mechanic's stethoscope and get to work. See if its coming from the top-end, bottom-end, or somewhere in-between. Don't be afraid to pull off a valve cover and put the stethoscope to each rocker stud. Mine started making a tick about 100 miles after a heads/cam change. Turned out to be a rod. Never heard a rod "tick" like that before - but that's what it was.
1995 LT1 Wagon. ERE 383
AtlantaDan is offline
post #6 of 21 (permalink) Old 09-29-2016, 10:40 PM Thread Starter
I'll record another video tomorrow. I'm honestly just afraid to harm the car any more.
post #7 of 21 (permalink) Old 09-29-2016, 10:43 PM Thread Starter
My gauge may be a little off, considering the engine sits in a 1979 corvette using that cars oem gauges. I just looked again and it's closer to 40psi hot idling around 600-650 rpm.
It does and has fluctuated a bit since I've got it running.
I'll use my scanner and see if I can get a more accurate reading on the oil pressure.
I just ordered new lifters for the cam I got, so I may just wait to fix it when the rest of the parts arrive.
I want to be sure it isn't something more catastrophic than that, the engine has about 125K on it.
post #8 of 21 (permalink) Old 09-30-2016, 05:30 AM
I wouldn't lose too much sleep just yet. It could very well be a noisy lifter or some other valvetrain issue (which would be my first guess), so wait and see. 125k is nothing for a well-kept LT1.
post #9 of 21 (permalink) Old 09-30-2016, 05:35 AM Thread Starter
Well I've ordered new lifters, springs, push rods, and a cam (CC503) as well as a new timing chain, I may just leave it parked until that gets done to avoid damage.
I do worry about my oil pressure. 50-60 psi while driving is ok? I've just put a lot into this swap work and the guy who sold me the engine was shady and knew it had problems when he sold it to me, just "forgot" conviently.
I'm a very paranoid person when it comes to mechanics, the smallest change in sound and I think it's about to explode.
post #10 of 21 (permalink) Old 09-30-2016, 08:24 AM
That sort of PSI while driving is fine for a fresh engine. Its that sort of pressure while idling - hot - that can be problematic, because it means your pressure goes up to 70 and beyond while driving. It can cause excessive wear on the oil-pump drive gear, cost horsepower, and even cause oil filters to explode.
The common metric that's cited for Gen 1 & 2 SBC's is 10 PSI per 1k RPM - hot - for a well-used, but still healthy engine.
Verify the pressure with a mechanical gauge. Then if it still reads high at hot idle, the relief valve on your oil pump may be stuck closed.
post #11 of 21 (permalink) Old 09-30-2016, 08:51 AM Thread Starter
It never exceeds 60psi.
I just uploaded a new video as well and attached a screenshot from my scanner.
https://youtu.be/WrDL_aipCt8
post #12 of 21 (permalink) Old 09-30-2016, 09:01 AM
What is the reading at say, 3k hot? (Also, I can't see anything in that picture - its too small.) If it stays at 60 psi at hot idle as well as hot 3k, then something is going on. Confirm pressures with a different mechanical gauge.
Back to the ticking - bad exhaust manifold gaskets can tick exactly like that as well.
A mechanic's stethoscope would be of great use to you in the search.
post #13 of 21 (permalink) Old 09-30-2016, 09:03 AM Thread Starter
What is the reading at say, 3k hot? Also, I can't see anything in that picture - its too small.
About 50 psi. That's close to what I run on the interstate (2750 rpm)
How do I make the picture larger for this forum?
post #14 of 21 (permalink) Old 09-30-2016, 09:07 AM
So wait... Its 60 PSI hot idle, and 50 PSI hot 3k? Meaning it drops 10 PSI at higher RPM's?
post #15 of 21 (permalink) Old 09-30-2016, 09:09 AM Thread Starter
No no I corrected myself it hovers closer to 40psi. It actually doesn't seem to change whether it is hot or cold.
