Lt1 tapping sound - Page 2 - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #16 of 21 (permalink) Old 09-30-2016, 09:26 AM
Originally Posted by Thomas Terry View Post
No no I corrected myself it hovers closer to 40psi. It actually doesn't seem to change whether it is hot or cold.
Check with another mechanical gauge. It shouldn't be your main concern now though. Find the tick.
1995 LT1 Wagon. ERE 383
AtlantaDan is offline
post #17 of 21 (permalink) Old 09-30-2016, 09:27 AM Thread Starter
About 50 psi. That's close to what I run on the interstate (2750 rpm)
How do I make the picture larger for this forum?
So wait... Its 60 PSI hot idle, and 50 PSI hot 3k? Meaning it drops 10 PSI at higher RPM's?
Here's another video, and forgive my daftness the car's hardly been on the road more than a month and I've just got off work from a long night.
https://youtu.be/xwxhgL12xsM
Thomas Terry is offline
post #18 of 21 (permalink) Old 09-30-2016, 09:38 AM
That looks normal. Is the car running true-duals with a sidepipe out either side?
post #19 of 21 (permalink) Old 09-30-2016, 09:40 AM Thread Starter
Yes true dual long tube headers, both sides.
The popping appears to only be driver side.
post #20 of 21 (permalink) Old 10-02-2016, 10:16 AM
Workman's Avatar
I would jack the car up , ( use jack stands ) and get under it and see if that noise is coming from the bottom end.
Workman is offline
post #21 of 21 (permalink) Old 10-02-2016, 10:21 AM
Workman's Avatar
Have you checked your oil yet btw ?
Glittery ?
Workman is offline
