Question What lifters and timing set to run on lt1 with the comp 292 - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 10 (permalink) Old 08-31-2016, 11:18 PM Thread Starter
Garage
I have an lt1 383 with the comp 292 cam I would like to know if the spider tray is going to last with this cam or do I need to go with link bar lifters also what timing set should I run on this call motor I want to keep the water pump and opti if possible
Youngmattg is offline
post #2 of 10 (permalink) Old 09-01-2016, 09:41 AM
Gotta provide year and opti type being used. There is no concern with the spider tray.
post #3 of 10 (permalink) Old 09-01-2016, 10:01 AM
Dynamic396's Avatar
Not a lot of choices if you want to keep the water pump drive. If I remember correctly, the LT4 HD timing set is the best you're going to be able to do.
The factory lifter setup is fine.
1995 Camaro Z-28, M6, 396 stroker, Scat forged 3.875" crank, Scat Ultra Q-Lite 6" H-beams, Icon forged pistons (4.030"), splayed 4 bolt w/ARP studs, 12.25:1, AFR 210 heads (2.08"/1.6", 58cc), Comp Ultra Pro Magnum XD 1.7:1 rockers, GM847 cam (234/242 .611"/.632"), Edelbrock LT4 air-gap intake, Spec Stage 3+ clutch, Fidanza aluminum flywheel, 24x conversion, 0411 PCM, TPIS 58mm, Bosch III 42# injectors, Aeromotive 340, Kook's stepped LT's -- SOLD TO MYSTERYBIRD
Dynamic396 is offline
post #4 of 10 (permalink) Old 09-01-2016, 10:42 AM Thread Starter
Garage
It's a 1994 Trans am
383 stroker
Full forge bondman flat top Pistons
AFR ported and polished heads
12.2-1 compression
Matched intake
Headers
Ect
I was told you can change to a vented opti by changing the timing cover but I will do what is best. The block is at Machine shop And I'm jest waiting on it to get back
post #5 of 10 (permalink) Old 09-01-2016, 12:22 PM
If you're going to go to a vented opti, I gave you the answers in the other thread you started. The lifters I suggested in that thread will work with just about any cam. Link bar lifters are not needed in your application. The spider will work just fine for many, many miles. If you are that concerned about it, get the GM LT1 lifter/spider/keeper kit.
You could just get the MSD cap/rotor kit and cobble together the vacuum bits to make it work. But if you really want to convert to the later opti, here you go:
95+ optispark. 1104032
95+ timing chain setup CLO-9-3651X3
95+ or aftermarket camshaft (due to needing a longer pin and deeper cam snout nose) Or you can just pull the cam and have a shop yank out the pin and install the correct pin since they're a different length. Were it me, if the OEM cam is coming out - its not going back in.
95+ vacuum harness. 12555323
95+ electrical harness. 12130319
95+ timing cover. 12552426
95+ vacuum fitting. 14082470
Originally Posted by Youngmattg View Post
383 striker
You've used striker twice now, so I suspect its intentional. BTW - its "stroker".
AtlantaDan is offline
post #6 of 10 (permalink) Old 09-01-2016, 02:09 PM Thread Starter
Garage
Sorry about the starting a new thread i was concerned did not state intentions and the striker/ stroker must have been auto correct damn technology. The reason I started a new thread Is there was only one answer on the old one so I changed some things
post #7 of 10 (permalink) Old 09-01-2016, 02:12 PM Thread Starter
Garage
Also is there a good timing set to run so I do not have to convert. I already have all the parts to do non vented opti. I will convert if need be
post #8 of 10 (permalink) Old 09-01-2016, 02:40 PM
If you stay with a spline drive opti, you are basically stuck with using a stock type timing set...and what Dynamic 396 said.
post #9 of 10 (permalink) Old 09-01-2016, 06:16 PM Thread Starter
Garage
Ok I gees we are going to the vented opti set up
post #10 of 10 (permalink) Old 09-01-2016, 06:17 PM Thread Starter
Garage
Any other suggestions on the build
