10-02-2006, 02:51 PM
#1
Fuel injector question?
I am putting my engine back together, but I am wondering if I neglected a few key areas. My real question is fuel. I have a 1996 WS6 and I am wondering how good the fuel injectors are. What horsepower level can they handle? I am putting in the engine 1.6 rockers, new pushrods, springs, and a cam with the specs of 210/224 @.050 272/286 advertised duration 112 lobe and .479/.518 gross lift. I did't do any porting or polishing or even touch the intake. I just want to know if the fuel injector will be able to handle it? I rrrreallly don't have anymore money to spend right now. Thanks.
__________________
1985 Pontiac Firebird WS6 Sold! time for a new project
1996 Pontiac Firebird Formula WS6 "Ladybird" #188
:streetrac
The few, the proud, and the hated.... The LT1 Owners
10-02-2006, 03:31 PM
#2
Full of Stupid Advice
your stock injectors should be good if you really need new injectors cheap try to find a whole fuel rail setup off a 98 z28 and rip off the injectors, those should be cheap and work fine (theyre 28lbs i think... not sure about all this though).
__________________
1996 Black Dodge Ram 2500 Long Bed Regular Cab Built 47RE CTD; #100 Fuel Plate Full Forward, AFE Stage 1 Pro Dry, MBRP 4'' Stainless Turbo Back Straight Pipe, DDP3 Sticks, KDP Tabbed, Starwheel Cranked, AFC Gutted, Boost Elbow, BFG AT 35''s, 2'' Leveling Kit, Galaxy CB, DiPricol Boost/Tranny/Pyro, 45 PSI, ATS Pulse Manifold, 3K GSK Springs, Farmboys Delivery Valves
10-02-2006, 07:14 PM
#3
the stocks should work just fine with that baby cam. Alto the only true way to know is by doing a datalog and measureing duty cyle.
__________________
~Cory Magner "My name is Cory, and I'm an addict."
95 DCM Buick RMS 14.21 at 91.79 "Jesus" Motor Swap at 85k
95 DCM Buick RMS 13.52 at 99.33 Buffmans Car Cracked Piston at 180k
RAISS, Tri-Y's, Pypes X pipe, Spintech Prostreets, 3000 Edge, 3.73's, Eaton Posi, and the rest of the Bolt-ons.
Coming soon! 845 cammed 96 9C1 engine.
And 7 other LT1 B-body's... Is there Rehab for this Sh*t?
You may not post new threads
You may not post replies
Our Friends:
