LS1LT1.com/LS3Forums.com
Presented by:
Register Tech/FAQ Members List Calendar Search Today's Posts Mark Forums Read
Premium Membership Videos Perf Tools Mobile/iPhone Link to Us! Social Groups Follow LS1LT1 on Twitter
Join us September 4, 2010 at the LTx Shootout! More Info...
Go Back   LS1LT1.com/LS3Forums.com > Engine Tech > PCM tuning & Computer Diagnostics
Share Thread Tools
Old 10-13-2009, 04:42 PM   #1
books4me2
books4me2 user's tech expertise is unknown at this point
Question Error Code 68
Can someone tell me how do I go about checking this code?
Code 68- A/C relay circuit fault. Check relay circuit for open or ground condition.
Where exactly is this relay? I changed all the relays under the hood in the black box...the fuses in the box...so what did I miss? I sent the car to the "shop" with the code...$200 later...the A/C isn't working constant...but the code is still there.
Yes I cleared it....
And Why is my O2 sensors still coding...Come on they are not even 6,000 miles and Denso so what gives? Ideas for why i have Code 44 and Code 64 also??
Please Help. I've been out of work for a year...and this is my only car. I can't afford any more "shop" people who seem to be causing me more damage than good lately.
books4me2 is offline   Reply With Quote
Old 10-14-2009, 03:53 PM   #2
bobdec
bobdec user's tech expertise is unknown at this point
Default
Here a pic ref shoebox.. http://shbox.com/1/hvac_compressor_control.jpg Code 68 says the PCM tried to pick the A/C clutch by grounding pin D8 and after that it did NOT sense +12 volts on pin D21 (output of the a/c relay). The relay is in the under hood box and is the same part number as the fog lamp, and fan relays . I assume you swapped it out already per your post, and replaced fuse 12 (20amp). From here on you will need a multimeter to figure out what's broken, by checking the circuit out. ALSO when working on a/c DTC's reset PCM after doing changes as the old codes may cause the a/c not to run
Code 44 & 64..If you are '94-95 then the O2 faults could be a O2 heater fuse, if '93 then it's a different story..
__________________
I'm Bob... 1994 Z28 A4, K&N CAI, 160 T-stat, LT4 Hot Cam, 1.6 RR, Pacesetter LT's, Corsa CatBack, Transmission Perform Switch, 3.42 rear, TunerCat $EE, FreeScan & TTS DataMaster-EE.
bobdec is offline   Reply With Quote
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2005 - 2010 by LS1LT1.com
Our Friends:
Recommended
Find technical articles on a Chevy Corvette, including tips and tricks on a Chevy Camaro and expert advice for Pontiac Firebird, along with reviews on the Cadillac CTS.
Featured
For your breakdown cover, get to Green Flag
Directline Car Insurance
Find car insurance to fit your budget
Sponsors
