LS1LT1.com/LS3Forums.com
Presented by:
Register Tech/FAQ Members List Calendar Search Today's Posts Mark Forums Read
Premium Membership Videos Perf Tools Mobile/iPhone Link to Us! Social Groups Advertiser Info Follow LS1LT1 on Twitter
Go Back   LS1LT1.com/LS3Forums.com > Engine Tech > LT1 | LT4 | L99 Engine Tech
Old 09-27-2009, 03:02 AM   #1
dansburntorangeta
dansburntorangeta user's tech expertise is unknown at this point
Default Cam Preferences?
Allright guys, I'm sending my heads off to the machine shop to get ported and polished. When I put the motor back together I want to install a cam. Allthough I've had a couple of Lt1's in the past I never dropped a cam in one.
So I need some opinions on which one is best. I've gone on youtube and watched dozens of videos of cams. I really like the sound of the Lt4 hot cam but Im still unsure.
I had a 93 lx 5.0 mustang with e series cam in it at one time. It sounded nasty. But sometimes when I would be sitting at a stoplight the car would just cutt off. Man that used to make me irate. I asked around then and everybody said it was a combo of the cam design and my auto trans.
My Camaro is going to have a auto trans in it and i dont want to have the same problem I did before. So any insight would be great!
dansburntorangeta is offline   Reply With Quote
Sponsored Links :: Login or Register to hide these ads.
Old 09-27-2009, 03:38 AM   #2
camaroz28383
camaroz28383 Apprentice Level Tech I
Default
first question is do you have emissions?
DD or weekend car?
sleeper or do you want it to shake the windows at the drive through
camaroz28383 is offline   Reply With Quote
Old 09-27-2009, 11:17 AM   #3
95Z
Global Moderators
95Z's Avatar
95Z Apprentice Level Tech II
Default
Read the cam sticky first, it will give you a good idea of what range of cam to look for and what is needed. You'll also need new valve springs and if you don't have a spring compressor decide which cam you want b/f you send the heads to the machine shop so you can have them install the right springs.
With a tune the car won't cut out with even a medium sized cam cc503 on stock stall, but if you go that big you really need a higher stall tc.
__________________
Yep its slow.
95Z is offline   Reply With Quote
Old 09-27-2009, 01:08 PM   #4
dansburntorangeta
Default
Im emisions free. In nc 95 and older has no emissions testing. So thats not a big worry. this car prob. wont be a daily driver but I will be driving it a lot. Also on long trips. We try to hit the dragons tail in the mountains a couple times a year and that is about 3 to 4 hours away.
As for the springs and stuff. Thats one reason I liked the lt4 hot cam. because from what I read you can just purchase the cam kit along w/ the cam and it comes w/ everything that I should need. Correct me please if im wrong. Luckily the guy that is going to help me freshen up and put my engine back together builds pro mod chevy's. So he has all the tools of the trade. He told me to ask around about the cams because although he can build and put them together w/ no problem, he is not as familiar with street cams as he is w/ race cams. A stall makes sense, I didn't have a stall in my stang and i prob. needed one.
Old 09-27-2009, 02:59 PM   #5
95Z
Global Moderators
95Z's Avatar
Default
Whats your budget?
The hot cam kit is the easiest way, but leaves power on the table.
__________________
Yep its slow.
Old 09-27-2009, 05:07 PM   #6
dansburntorangeta
Default
Well, it depends. I want to kind of find that happy medium where power meets cost efficiency. In all honesty (I think most would disagree), Im more interested in how it sounds then how much power it puts down. But since im spending the money, of course horse power gain is a plus.
I may put this car on the track a few times, but this car will mostly turn out as a cruiser. But whatever power it makes in the end, Im not going to hide it. Are there any cams and kits that make a lot more power for no more then a couple hundred bucks more then the hot cam?
Old 09-27-2009, 05:10 PM   #7
XtremeOracing
Supporting Member
XtremeOracing's Avatar
XtremeOracing Apprentice Level Tech I
Default
LE2 Head and Cam would set you back around $1700. Would make more power than LT4 Hotcam Kit.
__________________
1997 Chevrolet Camaro Z28 T-56
Do | You | Want | Some | Slaw | ?
2006 Yamah YZF-R6
Bone Stock
XtremeOracing is offline   Reply With Quote
Old 09-27-2009, 06:19 PM   #8
ShowNoMercy
10s or bust
ShowNoMercy's Avatar
ShowNoMercy Apprentice Level Tech III
Default
My LE2 setup sounds pretty mean, and if I ever put the money into suspension/converter, is capable of an 11 sec pass.
__________________
Spits, sputters, and smells...
12.3@115 NA... If only I could hook..
ShowNoMercy is offline   Reply With Quote
Old 09-27-2009, 06:31 PM   #9
03slowZ06
Administrator
03slowZ06's Avatar
03slowZ06 Apprentice Level Tech III
Send a message via Yahoo to 03slowZ06
Default
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH wait need to breath. ........ . ... . . . . OK. HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA.
11 sec my ass. Maybe 11.99999999999999999999 on the perfect day with a Pro driver and perfect track prep. Also you will have to strip the entire car and run just enough fuel for the pass.
__________________
Working on a LT1 is like making a deal with the Devil. For a minute you think are getting ahead. But we all know how its going to end up.
The Few, The Proud, and the Crazy... LT1 owners
Originally Posted by 94FormulaBird View Post
drivers side is a dream....passenger side on the other hand...i lost 2 screwdrivevers and a socket when i chucked them in the woods
u can do it
I am permanently banned from all petting zoo's for getting to friendly
03slowZ06 is offline   Reply With Quote
Old 09-27-2009, 06:35 PM   #10
ShowNoMercy
10s or bust
Default
Huh?
Local guy is running 11.7X... full weight car... exact same cam, and heads.
I can get you a video of it if you don't wanna believe it. And its on a 1.7-1.8 60 foot... so not sure why you laugh.
Proof for the doubter.
http://videos.streetfire.net/video/8...z28_706529.htm
Older video, he got a new best of 11.7 the other week...
__________________
Old 09-27-2009, 06:46 PM   #11
CraZ28
93 LT1 T56
CraZ28 user's tech expertise is unknown at this point
Default
Huh?
Ya Vette boy! You need weight for high horsepower, that's why you run an Iron block!
O' and original poster, a cam, valve springs, gaskets, and a liitle knowledge will get you more safe, useable power for the buck than anything else!
CraZ28 is offline   Reply With Quote
Old 09-27-2009, 06:52 PM   #12
03slowZ06
Administrator
03slowZ06's Avatar
Default
Huh?
That is not a head cam only car sorry. Anybody can claim anything. My Z runs 12's. Bring your little h/c on down and we will see what your 11 sec car looks like next to it.
Oh and Crazy. WTF are you talking about? You need weight for high HP? My car is much lighter and makes more HP then both of you two's cars.
SNM seems you have found the perfect side kick.
__________________
u can do it
Old 09-27-2009, 06:54 PM   #13
03slowZ06
Administrator
03slowZ06's Avatar
Default
^^^ This has been the only usefull post in this thread. Disregard the rest.
__________________
u can do it
Old 09-27-2009, 06:56 PM   #14
ShowNoMercy
10s or bust
Default
Ok?
A member on here, stealthformula ran a 11.88@114 w/ 1.65 60' with an LE2 combo. So not sure where the logic that this combo cannot net you a 11 sec pass, I mean sorry its not a fancy vette, but I don't get your logic.
But ok... I will continue to live in my day dream I guess.
__________________
Old 09-27-2009, 06:56 PM   #15
2fast4u88
Supporting Member
2fast4u88's Avatar
2fast4u88 Apprentice Level Tech I
Default
I think show could pull it off. He has lost some weight as it is. Along with if he could hook with 400whp he should be right around a 12 flat. Along with the stall should help. Then plus he has the 100 shot. I believe that's right isn't is show? Any way he should be in the mid to low 11's.
__________________
1995 T/A M6: -Tops,390 Eagle Forged Fully Built Stroker,Procharged at 12lb'z(Currently Down)
1995 T/A M6:Hard Top,Lowered 1.5in. on B&R Springs,3pt. Subframe Connectors,Pro 5.0 short throw,K&n Cold Air Intake,2 1/2 Cowl industion hood,Ws6 Wheels,Cc502 cam,No Emissions, Descreened Maf,Tb Air Foil,1.6 Roller Rockers, Professional Products Sfi approved balancer with Steel Keyed Hub,New Opti,Msd 8.5 wires,Ngk tr55ix plugs,Pacesetter Longtube Race Headers, ORY & Flowmaster Catback
2fast4u88 is offline   Reply With Quote
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2005 - 2007 by LS1LT1.com
Our Friends:
Recommended
Find technical articles on a Chevy Corvette, including tips and tricks on a Chevy Camaro and expert advice for Pontiac Firebird, along with reviews on the Cadillac CTS.
Featured
For your breakdown cover, get to Green Flag
Directline Car Insurance
Find car insurance to fit your budget
Sponsors
