LS1LT1.com/LS3Forums.com
Presented by:
Register Tech/FAQ Members List Calendar Search Today's Posts Mark Forums Read
Premium Membership Videos Perf Tools Mobile/iPhone Link to Us! Social Groups Follow LS1LT1 on Twitter
Join us September 4, 2010 at the LTx Shootout! More Info...
Go Back   LS1LT1.com/LS3Forums.com > Engine Tech > LT1 | LT4 | L99 Engine Tech
Share Thread Tools
Old 06-05-2009, 07:02 PM   #1
awizeking
Supporting Member
awizeking's Avatar
awizeking Apprentice Level Tech I
Default stock pushrod lenght
what is the stock pushrod lenght on a lt1?
__________________
Just a modderatly modded TA
awizeking is offline   Reply With Quote
Old 06-05-2009, 07:10 PM   #2
awizeking
Supporting Member
awizeking's Avatar
Default
ok i found out my push rod lenght stock being 7.200, but some how i measured 7.430?? am i just stupid an need to remeasure or can somthing be wrong?
__________________
Old 06-05-2009, 08:40 PM   #3
ShowNoMercy
12s for life.
ShowNoMercy's Avatar
ShowNoMercy Tradesman Level Tech I
Default
You measured the physical length of the stock pushrods?
__________________
Una salus victis nullam sperare salutem
ShowNoMercy is online now   Reply With Quote
Old 06-05-2009, 08:45 PM   #4
awizeking
Supporting Member
awizeking's Avatar
Default
yea with the pushrod lenght tool, maybe i did somthing wrong but their was a noticable gap between the rod an new rockers.. my lifters are in perfect shape so i know its not the lifters.
__________________
Old 06-05-2009, 08:53 PM   #5
ShowNoMercy
12s for life.
Default
Well, did you do it with the springs on the valves? You prob depressed your lifter and got the larger reading...
__________________
Old 06-05-2009, 09:01 PM   #6
awizeking
Supporting Member
awizeking's Avatar
Default
i left the heads on an took the old rocker an push rods off, put in my new cam an put the lifters in an put the stock rods back in with the new rockers an their was a noticable differance. i called AI an they said i measured it wrong. am i missing somthing??? the reason i went this rout is because i need to tell AI what my lenght is so they can send me my chromoly push rods. then after i got the correct size i was gonna take the heads off an put my new springs on while im waiting for shipment, reason being so i can have less down time.
__________________
Old 06-05-2009, 09:03 PM   #7
ShowNoMercy
12s for life.
Default
Ok so springs were still on when you turned over the engine by hand?
Cause if so, you depressed your lifter and you gained however much...
__________________
Old 06-05-2009, 09:07 PM   #8
awizeking
Supporting Member
awizeking's Avatar
Default
ok ya i did do that, i didnt realize i depressed the lifter... im still a newbe at this but im glad i asked cause i almost had them send me 7.450 push rods, that would of been bad juju. thanx alot for your help sho no i really apreciate it!
__________________
Old 06-05-2009, 09:08 PM   #9
ShowNoMercy
12s for life.
Default
Yup, you either need to run a solid type lifter for the measuring part, or run a weak spring as to not depress the lifter.
__________________
Old 06-05-2009, 09:12 PM   #10
awizeking
Supporting Member
awizeking's Avatar
Default
i already set the valve clearnce an then i checked the length
__________________
Old 06-05-2009, 09:15 PM   #11
ShowNoMercy
12s for life.
Default
Yea, well, you may need to make a solid lifter then.
__________________
Old 06-05-2009, 09:16 PM   #12
awizeking
Supporting Member
awizeking's Avatar
Default
make or buy?
__________________
Old 06-05-2009, 10:02 PM   #13
awizeking
Supporting Member
awizeking's Avatar
Default
ok i found out how to make a soild lifter, i need to take a lifter with the same diminions an take it apart. then i need to fill the lifter with washers so the spring or plunger thing doesnt move at all. or i can take weld the plunger inside the lifter so it doesnt move. i will do this tomorrow an then check my push rod lenght again.
__________________
Old 06-05-2009, 10:03 PM   #14
ShowNoMercy
12s for life.
Default
That or take off the valve spring... may be easier.
__________________
Old 06-05-2009, 10:07 PM   #15
awizeking
Supporting Member
awizeking's Avatar
Default
i didnt know you get measeure accuratly with the spring off, shows how much of a newb i am but thanx again man!
__________________
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2005 - 2010 by LS1LT1.com
Our Friends:
Recommended
Find technical articles on a Chevy Corvette, including tips and tricks on a Chevy Camaro and expert advice for Pontiac Firebird, along with reviews on the Cadillac CTS.
Featured
For your breakdown cover, get to Green Flag
Directline Car Insurance
Find car insurance to fit your budget
Sponsors
