04-14-2009, 05:21 PM
#1
what will it run in the 1/4 mile??
i was wondering what my 95 z28 lt1 a4 would run having slp cold air intake, msd coil, mac cat back exhaust, ported throttle body, air foil, and aluminum drive shaft, with Goodyear street tires and everything else stock 72k miles
i was hoping to get below 14.0
if you dont think i can get it below 14 what other mods (relatively cheap) could i do to get it into the 13s
i have not run the car yet so i'm trying to get an idea of what it will run
thanks
__________________
95 Camaro z28 A4
SLP CAI, MAC Catback, Ported TB, MSD Blaster Coil, 3.23s, Pacesetter Ceramic Coated Long Tube Headers, Pacesetter ORY
13.622 at 102 (before PS LTs and ORY)
04-14-2009, 06:12 PM
#2
mid 13s if it hooks with your mods
04-14-2009, 06:14 PM
#3
you really think it will run mid 13s with just that???
that would be great
__________________
95 Camaro z28 A4
04-14-2009, 06:59 PM
#4
Supporting Member
yup as long as your a good driver!
__________________
Just a modderatly modded TA
04-14-2009, 07:04 PM
#5
Global Moderators
idk it depends what gears you have, btw the goodyears won't hook too well either. I'd say right around 14, little over if its a 2.73 car little under if its 3.23.
__________________
Yep its slow.
04-14-2009, 07:13 PM
#6
13.7 with good driving
__________________
Heath Lewis
4 bolt main, M6, Hooker LT's, Crane 1.6 golds, LT4 km, Trickflow pr's, tr55's, Comp cc306, type R's, 918's,
Cloyes timing set, melling HP 10554, ARP bolts, PCMforless tune, Msd coil, 160 stat, aluminum elbow
04-18-2009, 08:10 PM
#7
just ran 13.622 at 101.58 with street tires with mods in sig
__________________
95 Camaro z28 A4
04-19-2009, 11:00 AM
#8
1/4 Mile 13.5 at 99MPH
Dam good job
__________________
Originally Posted by Brett@XP-Racing
you don't need 4 gears to beat a mustang....you only need 1 hahahaha by then you will be so far ahead there is no need to shift
Originally Posted by cocobolo95
Had a girlfriend that gave me the choice, the car has to go or I do. Still have the car.
04-19-2009, 11:35 AM
#9
Global Moderators
Good times!
What gears do you have and what were your 60' times if you don't mind me asking?
__________________
Yep its slow.
04-19-2009, 05:26 PM
#10
gears im not positve but i want to say 2.73 60' times were 2.01
__________________
95 Camaro z28 A4
04-19-2009, 05:29 PM
#11
damn good times
__________________
Tyler's 1993 Chevrolet Camaro Z28
6LE Longtubes / LPM Heads / LE Cam / Vigilante 3200 / Shinholster 4L60 / GM 3.73's
04-19-2009, 05:42 PM
#12
dam thats good times for 2.73
check the glove box to be fully sure
GU2 - 2.73's = 2 series carrier
GU5 - 3.23's = 3 series carrier
__________________
04-19-2009, 06:08 PM
#13
Senior Member
great times man
04-19-2009, 06:29 PM
#14
thanks ill remember to check what gears
__________________
95 Camaro z28 A4
04-19-2009, 06:34 PM
#15
are 2.0 60' good or bad??
where should i be able to pick up time as it is??
__________________
95 Camaro z28 A4
You may not post new threads
You may not post replies
Our Friends:
