05-06-2008, 07:17 PM
#1
ARP STUDS
I am installing arp main studs in my block,according to arp,only tighten studs in block hand tight?anyone else using arp studs?if so what did you do?
__________________
Just a little lt1....  .020 over on the block,comp custom cam,comp push rods,comp 1.6 rrs,and lifters,cnc stock ported heads,edelbrock ported air gap intake,58mm t/b,pacesetter LTs,Summit 2.5 x-pipe kit with dynomax bullets,march underdrive pulleys,gm opti,msd cap and rotor,Moore 10mm race wires,Ngk tr55s,SLP line lock,SPEC 3 clutch,aluminum D/S,3.73s,and much more..
05-06-2008, 09:41 PM
#2
Administrator
Ed Zachary...Hand tight in block and then torque as necessary. It torques from both top and bottom from rather just the top down.
__________________
Chris
The Few, The Proud, and the Crazy... LT1 owners
Something wicked this way comes!!
Originally Posted by SStrokerAce
BTW Chris.... you're going to think this new cam is INSANE!!!! Then again it is, not many guys with a LT motor have that many cubes and want that RPM with a hyd roller!!!!!
05-06-2008, 11:14 PM
#3
I've used ARP studs thousands of times - yes, they're only finger tight in the block.
Since it's right in the ARP sheet that came with the studs, why would you question?
__________________
1995 Impala SS
400 HP LT1 383 project on the stand
"You know you got to go through Hell before you get to Heaven"
05-07-2008, 04:53 AM
#4
im just a little nervous,first time using studs...i have alot of money invested in this engine...
__________________
05-07-2008, 08:07 AM
#5
I was just poking a bit - I hear you  Finger tight seems wrong somehow, I know.
__________________
1995 Impala SS
05-07-2008, 08:48 PM
#6
Administrator
I mean...even if you just tighten the studs in the block like torque specs, and tighten the nuts on w/ some arp assembly moly lube then if the studs dont' turn anymore it'll just be like using head bolts.
__________________
Chris
05-07-2008, 08:50 PM
#7
12s for life.
Throw a 4inch pipe wrench on the studs and tighten em up.
__________________
Una salus victis nullam sperare salutem
05-07-2008, 09:32 PM
#8
*chuckle* The prop nut on my airplane requires *280 lbs-ft*; I have a calibrated "breaker bar" to tighten it
__________________
1995 Impala SS
05-07-2008, 09:40 PM
#9
Administrator
2 words Bill... torque multiplier, those things are nice...yet very expensive.
I forgot how much ft lbs. the caps on hydraulic cylinders take, but usually its torqued w/ a 3 ft pipe wrench and gentle pressure from an excavator while being held w/ another one on that ones tracks
__________________
Chris
You may not post new threads
You may not post replies
Our Friends:
