The proper term is Shift Kit.
If you are looking for better (firmer) gear changes then the shift kit is the way to go.
All automatic transmissions have torque converters. What your friend was talking about was one with a higher stall speed. (rpm at which the converter engages) The higher stall torque converter will allow you to launch the car at a higher rpm from a dead stop and also when moving and you down shift (ie: mash the gas to the floor) it will get the engine into its power band faster.
Note if you do go to a higher stall speed TC you will need to get an add on transmission cooler. The higher stall will generate higher transmission temperatures.
Higher temps are certain to shorten the life of the transmission.
__________________
_______________
Robert
1995 T/A - Mods: Who really cares ... Its just another damn LT1, right?
courtesy of So Sick Photography - www.sosickphotography.com
Sacfbodyz 3 of 5
_______________
