LS1LT1.com is the premier LSx Forum on the internet. We discuss all LS models on the forum. Registered Users do not see the above ads. Please Register - It's Free!
03-09-2010, 12:28 AM
#1
Redlight sleepin since 08
All gears work but I cannot manually put shifter in first.
This has been something that has been like this since I bought the vehicle but I never really thought too much about it because it wasn't causing any problems like some other repairs that needed more immediate attention. I cannot, for some reason, get the shifter in first. First gear is there and working properly. No slipping. I just can't pull the shifter lever down to 1. It stops at 2 and pulling on it any further it just wont go down into first. It's a pain in the ass when I am trying to slow down quickly and save my brakes some. Any reason why it would be doing this? About a month before I bought the car, the previous owner said the original tranny went on him but he had one from another caprice lying around and he just threw it in. Could this be an installation error? I also have a slow tranny fluid leak but I always keep up with it and never let it get too low. Any thoughts?
1995 Caprice Classic Wagon, LT1, K&N FIPK Gen II CAI, Custom True Dual Catback Straight Pipes, Throttle Body Bypass, 160*F Thermostat, A/C Bypass Pulley, 9C1 Air Valence, Home Plate Delete, Manual Fan Switch, Lowered Suspension.
Plus It Seats 9!!!
And a 1992 Honda Civic DX SOLD
03-09-2010, 04:54 AM
#2
34 views and no one has a single idea?
Plus It Seats 9!!!
03-09-2010, 07:25 AM
#3
15 second club
i dont know if your car would have something similar, but here's my idea. on my camaro, you could only go down to second manually. there is a block of plastic that was blocking the shifter from getting first. I think it had something to do with EPA regulations or something. anyway, i just pulled my shifter cover off and cut off that little piece of plastic, and viola, i had first. like i said, i dont know if your car has something similar, but its something to look into!
Chrys
96 Formula M6- Pacesetter LT's, ORY, Flowmaster exhaust, cc500, AIR/EGR delete, A/C delete, de-screened MAF, Z06 wheels.
Originally Posted by preston
i crouched down and she laid down between my legs rolled over onto her back and just stared at me.
03-09-2010, 07:37 AM
#4
The issue might actually be a safety that was used years ago. On the pan rail in some caprice units for squad cars, there is a small bracket that actually acts as a stop. The shifter linkage arm will hit this piece when trying to go to manual low. In squads this was used to keep officers from blowing up transmissions. Just a though and this might be the issue that you have. Vince
03-09-2010, 10:07 AM
#5
like it was said, not every car can drop down into first. depends on the rear gear choice.
you shouldn't manually shift a 4l60e unless it was built for it.
Originally Posted by bootlegger
i think i just saw the kim kardashian of lt1's...
03-09-2010, 11:16 AM
#6
Global Moderators
Agreed 100%
Brakes are cheap, transmissions are not.
Yep its slow.
03-09-2010, 12:15 PM
#7
^^^ x2, it will run you like 1k or more for a nice rebuild
Tyler's 1993 Chevrolet Camaro Z28
6LE Longtubes / LPM Heads / LE Cam / Vigilante 3200 / Shinholster 4L60 / GM 3.73's
03-10-2010, 03:12 AM
#8
Thanks for all the advice guys! Well if it's not broken and not meant to be put in first then I suppose there is no reason to alter it haha. The tranny came out of a caprice sedan. It was very possibly a 9c1. Thanks everyone
Plus It Seats 9!!!
03-11-2010, 07:20 AM
#9
Just so you know, the bracket I spoke about in my first post can simply just be removed. It's two bolts to be removed and then just install the two bolts back in. Next time you are under your car take a look. I hope this helps you. Vince
03-11-2010, 06:54 PM
#10
I'll take a look to see if that is what I have next time I'm working on it. Just to make sure that there isn't actually anything at all wrong with it haha.
Plus It Seats 9!!!
