11-18-2009, 02:04 AM
#1
Boost port?
I'm just wondering if anyone can tell me were to hook up a boost vacumm gauge on an lt1. I've tried on the side of the throttle body but I only get boost and no vaccume reading, I've also tired on the driver side and I get vaccum readings but no boost reading. Were did everyone else hook up the vaccumm line.
1995 Firebird Formula, 5.7 lt1 350, 58mm throttlebody, headers, powerdyne supercharger, MSD ignition, FMU, 275/40/17 front and 315/35/17 rear tires.
| Sponsored Links :: Login or Register to hide these ads. |
11-18-2009, 05:54 AM
#2
What kind of boost you have? Turbo or sc.
11-18-2009, 08:00 AM
#3
LS1LT1.com Sponsor
It needs to be on the intake manifold behind the throttle body. Im trying to figure out how you got a port to read vacuum but wouldn't read boost. I can understand the port that only saw boost but any port that sees vacuum should also see boost on a FI engine.
11-18-2009, 10:31 AM
#4
yea I kinda thought it was weird, my only thought is mabee the gauge is bad.
11-18-2009, 11:02 AM
#5
Supporting Member
T it up here.
1997 Chevrolet Camaro Z28 T-56
Do | You | Want | Some | Slaw | ?
2006 Yamah YZF-R6
Bone Stock
11-18-2009, 08:38 PM
#6
yea thats were its hooked up right now, but I'm not seeing anything but vacum. And the supercharger seems to be running fine and still burning the tires.
11-19-2009, 12:29 AM
#7
Supporting Member
Take a air compressor and blow air in the line. Only a little and see it it will read psi that way. Either it is the gauge or you have a boost leak somewhere. That or the gauge line.
1995 T/A M6: -Tops,390 Eagle Forged Fully Built Stroker,Procharged at 12lb'z(Currently Down)
1995 T/A M6:Hard Top,Lowered 1.5in. on B&R Springs,3pt. Subframe Connectors,Pro 5.0 short throw,K&n Cold Air Intake,2 1/2 Cowl industion hood,Ws6 Wheels,Cc502 cam,No Emissions, Descreened Maf,Tb Air Foil,1.6 Roller Rockers, Professional Products Sfi approved balancer with Steel Keyed Hub,New Opti,Msd 8.5 wires,Ngk tr55ix plugs,Pacesetter Longtube Race Headers, ORY & Flowmaster Catback
12-02-2009, 08:33 AM
#8
LS1LT1.com Sponsor
Only other thing is an internal pcv of some sort? Im not 100% familiar with the LTx engines.
12-02-2009, 11:47 PM
#9
Supporting Member
Mine was fine with the pcv valve installed in the intake. But I ran a filter on the valve cover. So that shouldn't be his problem. Or atleast I wouldn't think so.
01-17-2010, 07:22 PM
#10
i was reading this thread and no one responded a solution. I am having the same issue,i moved the gauge to the drivers side of the intake and i'm only getting vacuum readings. Please respond
01-18-2010, 01:24 PM
#11
Supporting Member
Mine is hooked up the same way as 2fast4u ,I get boost and vac readings
01-18-2010, 06:12 PM
#12
hey man do you have any pic's so i could see exactly how you have it??
