11-06-2009, 06:45 PM
#1
what 350 can i use
I have a v6 firebird and the motor went on strike but I was told that I can put a 350 motor in without changing the wireharness/computer out but I was never told what 350 motor to use do any1 knows what motor I can do this with ?
| Sponsored Links :: Login or Register to hide these ads. |
11-06-2009, 07:15 PM
#2
what year firebird do you have? you can put almost any motor in to any car... i dont know about the CPU's or wiring harnesses
198?-1992= TPI
1993-1997= LT1/4
1998-2002= LS1,2,6,7.....ect...
11-06-2009, 07:18 PM
#3
You can't. You can swap the motor out with either an LT1 or LS1 (both 5.7L 350ci) depending on what year firebird your's is. I assume it's a 4th gen V6. You'd need complete harness, k member, PCM (computer) and a load of other stuff.
Tracy
1997 LT1 Firebird Formula
"You don't have to think fast if you move slow" - Red Green
11-06-2009, 07:34 PM
#4
Its a 97 I know almost what's needed for lt1/4 swap but the guy told me I could go
Carb or injection if fuel inject I would have to do a complete harness/computer change if I go carb I don't have to change harness or cumputer he saids the motor came out of a truck
11-07-2009, 02:20 AM
#5
if u go carb ur gonna have to cut into the cowl and have a hood to clear the breather and ur gonna have to get the computer tuned im pretty sure
since urs is a 97 u need to swap in an lt1
i dont know too much about the swap mabye someone else can chime in to help.
1996 Camaro Z28 212,XXX miles on body and 69,000 on lt1,leather,M6,t-tops,true dual glasspacks,cai,maxxis tires..LT's eventually
11-07-2009, 02:22 AM
#6
lsx swap it you will be much happier, and it will still pull 20 mpg, instead of a slug carbed 350
1993 Chevrolet Camaro Z28
11-07-2009, 03:38 AM
#7
I get 24mpg on the highway with my Lt1. And my car weighs almost 4500 lbs haha
1995 Caprice Classic Wagon, LT1, K&N FIPK Gen II CAI, Custom True Dual Catback Straight Pipes, Throttle Body Bypass, 160*F Thermostat, Intake Silencer Delete, Manual Fan Switch, Lowered Suspension.
And It Seats 9!!!
11-07-2009, 06:39 AM
#8
Just one thing you should know, a carb'd engine in a 97 isn't going to pass emissions if that's a concern where you live.
Tracy
11-07-2009, 07:51 AM
#9
finding a '93-95 LT1 i think would be cheaper then doing a motor swap
