New Gears - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 8 (permalink) Old 01-10-2013, 07:14 PM Thread Starter
Bluehawk's Avatar
New Gears
Ok so I have an auto and I have decided that for my next upgrade I want to upgrade my gears. I think I have 2.73 but I dont know how to tell. Anyways its a daily driver so would 3.73s be good? Good on the highway? And what would my car top out at?
I love my T/A
Bluehawk is offline
post #2 of 8 (permalink) Old 01-11-2013, 08:11 AM
3.73's are a great all around gear accompanied with the 4l60e. Is a great upgrade and you wont regret it.
Mystery Bird is offline
post #3 of 8 (permalink) Old 01-11-2013, 09:05 AM
There's a code in the glove box that tells you your gear. What's even easier is if you have gear "1" on your selector, you have 3.23's. At least that's how I remember it. 2.73's were too loud for gm to put in a select for gear 1 apparently.
Sent from my Galaxy Nexus using AutoGuide.Com Free App
1994 Camaro Z28 19x,xxx miles New LT1 and built 4L60E - K&N CAI, Elbow, Air Foil, kooks LT headers, True Duals w/ Dynomax Bullets dumped, 160 stat & fans on early, EGR & AIR delete, EWP, 255FP, ProTrorque 3200 stall, Pcm for Less tune, ET Streets 12.886 @105.12 1.779 60'
Xzauhst is offline
post #4 of 8 (permalink) Old 01-11-2013, 09:10 AM
BoneStock95Z's Avatar
just to be curious, what brand gears are you planning on going with?
95 z28 a4, 3500lbs race weight, Moroso CAI, 1LE elbow, free mods, 1.6 nsa RR, 7/16 studs, guideplates, hardened pushrods, cutout after the cat. Current 1/4 mile:13.47 @ 102.56 mph Corrected time: 13.39 @ 103.65 mph Goal:12.5 with bolt-ons.
BoneStock95Z is offline
post #5 of 8 (permalink) Old 01-11-2013, 11:36 PM Thread Starter
Bluehawk's Avatar
I have no idea, what brand is good?
I love my T/A
Bluehawk is offline
post #6 of 8 (permalink) Old 01-12-2013, 06:37 AM
I've used Motive before with good luck.
post #7 of 8 (permalink) Old 01-14-2013, 05:49 AM
Justin Hover's Avatar
Check your door code...GU2 is 2.73. Get motive 3.73s, you'll love them.
slp cai..p&ptb..ls6intake...pacesetter lts..tsp true duals..4000revmax stall..motive3.73s..UMI strut..lcas..ta..
ph rod..bilsteins/springs..poly mm..frost tune.
Tick performance SNS stage 3 234/244 111+3...performance built transmission
Justin Hover is offline
post #8 of 8 (permalink) Old 01-14-2013, 08:58 AM
Motive or Richmond are two of the best brands. The amount of noise all depends on the setup really.
