what gear ratio - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 11 (permalink) Old 01-19-2011, 09:20 PM Thread Starter
what gear ratio
My 96 SS slp Camaro A4 is all original and stock I was wondering what gear ratio it has in the rear end I know it is a torsen carrier. The pinion has play in it and leaks. I can get a low mileage 3:42 complete rear out of a 2001 Camaro for 350 bucks is it the same ratio and is it much trouble to change out. I would like the bigger brakes also as an added bonus. Pre thanks Edd
Last edited by edd gordon; 01-19-2011 at 09:21 PM. Reason: meant to say changing whole carrier
edd gordon is offline
post #2 of 11 (permalink) Old 01-19-2011, 09:23 PM
Yo!
R3DLT1's Avatar
A 98-02 rear end won't bolt on to our LT1 with out any kind of modification.
R3DLT1 is offline
post #3 of 11 (permalink) Old 01-19-2011, 09:48 PM Thread Starter
What mods? I seen a 98 -2002 on a 95 camaro and the man told Me only a few things need changing. Can anyone tell what needs doing thanks again guys
post #4 of 11 (permalink) Old 01-20-2011, 10:47 AM
10 Second Opti Club
sweetbmxrider's Avatar
Is the 95 a traction control car?
sweetbmxrider is offline
post #5 of 11 (permalink) Old 01-20-2011, 01:52 PM
Sure it will What you need to know is whether or not the axle from the 01 is a 3 channel or 4 channel rear. You will need the 4 channel if you have traction control. If you dont have TC, you want a 3 channel rear. The difference between the two is that the 3 channel has the reluctor wheel mounted to the differential inside the housing and the sensor goes through the top. A 4 channel(TC) axle will have one reluctor wheel on each axle and a sensor running through the brake caliper.
1994 Z28 A4
Best ET 10.87 @ 123.66 - 1.49 60 ft - +1600 DA
Under the knife again... LE Victor EFI, Holley Dominator ECU, 13.5:1, E85, Custom SR
PA94Z is offline
post #6 of 11 (permalink) Old 01-20-2011, 07:20 PM Thread Starter
pa94z My 96 SS has NOT TC so I will find out tomorrow when the rear is pulled from the 01 if it has the reluctor on it or not. Now if it has the 4 channel can or cannot I use it on My non TC 96 SS? Thanks alot for the info and I am learning alot from You guys so thanks again
post #7 of 11 (permalink) Old 01-20-2011, 11:55 PM
Unless you are willing to give up your Anti Lock Brakes then no, you do not want a 4 channel rear.
1994 Z28 A4
PA94Z is offline
post #8 of 11 (permalink) Old 01-21-2011, 03:26 PM
Yo!
R3DLT1's Avatar
Well aren't the rotors bigger on the ls1 body than the lt. Wat about the brake line?
I was just saying bc junk yard that focuses on f bodys told me that a 98+ rear won't work on a lt1 with out any modification
R3DLT1 is offline
post #9 of 11 (permalink) Old 01-21-2011, 04:28 PM
Yea the junk yard is full of it. You are right the brakes are bigger, i forgot that, but they will fit also. I guess you'd have to get the whole assembly including brakes. The brake lines may be a little different also..i wouldn't say it doesnt bolt in because of that though. As far as suspension geometry etc all that stuff bolts right up.
1994 Z28 A4
PA94Z is offline
post #10 of 11 (permalink) Old 01-21-2011, 04:45 PM Thread Starter
brakes are bigger
Place that has the 3:42 rear says it is a three chanel and will work in My 96SS with a few mods and will give Me instructions to do so. He has done alot of them before. I am also converting the from brakes too the larger LS1 set up. Thanks again guys for Your imput and if You have anyother ideas let Me know. My next mod will be converting the A4 to M6 as soon as I get the parts. I am retired and have the time to do so. My SS is not My everday driver so I can avail Myself of the mods without concerns of time frame. I am also looking at this time looking to find a 2002 SS or WS6 for another fun car to drive. I have owned over 25 Camaros in My 66 years of living on this earth and at least 12 Trans Ams. F-Cars forever Guys Big thanks to You all Edd
post #11 of 11 (permalink) Old 01-21-2011, 05:14 PM
Yo!
R3DLT1's Avatar
Dam! That's a lot of f bodys!
R3DLT1 is offline
