Need a stock tune for a 95 auto vette - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Go Back   LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums > Engine Tech > PCM tuning & Computer Diagnostics
Old 01-07-2013, 01:20 PM   #1
AF_Z28 user's tech expertise is unknown at this point
Default Need a stock tune for a 95 auto vette
I am trying to help a buddy with his vette, we think he fried the ECM so he is ordering a new one. But I need a tune to flash the new ECM and monodax is still down. Any help would be greatly appreciated!!!
AF_Z28 is offline
Old 01-07-2013, 05:42 PM   #2
can you pull the bin from the old ecm?
they are checksummed -- so if the bin is corrupt, it should warn you when you try to download it from the ecm..
Old 01-07-2013, 10:14 PM   #3
I will try to pull the bin. when we datalogged it, it would record data for 5-10 sec then loose connection for 5-10 sec over and over again. When it lost connection the service asr/asr off lights would come on. Also we think his car is stuck in "limp home mode" but its not throwing any codes, I'm confused, any ideas?
AF_Z28 is offline
Old 01-08-2013, 07:17 AM   #4
There is one on this site for a 94. LT1_Edit Files Database
Best 1/4 so far 11.20 @ 118.42 1.53 60ft 3700lbs 1900 DA.
Mystery Bird is offline
Old 01-08-2013, 10:58 AM   #5
might want to double-check that ground connection to the ecm, make sure its tight/clean and the wire isnt damaged
i know on the fbody, the aldl ground tees into the fuel pump relay ground wire, which is the same wire as the pcm block ground.. i bet it's the same on the vette..
all you need for datalogging to work is keyswitched power, constant power, ground, and that one data wire.. nothing else matters
i just ran into an ecm that was fried, but apparently its very very rare, and it was due to miswiring
Old 01-08-2013, 01:26 PM   #6
A repository .bin files can be found here.. Index of /gearhead-efi/bin scroll down and click PCM part number 16181330 and there are two Y body A4 .bins there or scroll to 16188051 and click, there are about 13 .bins there saw F &,B .bins but did not view all to see if a Y was there. You will have to download and open each w/tunercat to view correct vehicle info.
bobdec is offline
