what do.these codes mean - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Go Back   LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums > Engine Tech > PCM tuning & Computer Diagnostics
Old 11-18-2012, 09:43 AM   #1
that transamkid's Avatar
that transamkid user's tech expertise is unknown at this point
Default what do.these codes mean
26 quad driver module error
28 auto trans range switch error
21. Tos signal hi
How can I fix these problems?
On my 93 trans am
93 trans am ws6 hood and air box. Pass setter headers strait pipes . Lowered on 99 SS replica
that transamkid is offline
Old 11-19-2012, 09:59 AM   #2
Here is a page from shbox.com. http://shbox.com/1/Dtcs.htm . The '93 ECM tested solenoid or relay circuits in groups. They call the error a QUAD driver XX. The 26 is a quad driver module (QDM #1) open/shorted air pump relay or EGR solinoid or EVAP solinoid. You have to figure out which of the 3 are defective. The DTC 28 is QDM #3 is open/shorter AC relay or fan relays. If you have any of the circuits open (deleted) or the fuses are blown you will see those DTC's. The DTC 21, as coco mentioned, is a Throttle Position sensor high, it says you TPS voltage to the ECM is reading to high at idle (over 2.4 volts) -or- to high when running (over 4.5 volts). Reset it, if it comes back could be bad TPS or a bad connection/wire from TPS to ECM.
bobdec is offline
