hard clutch vibration? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 11 (permalink) Old 05-12-2011, 02:25 PM Thread Starter
96 lt1's Avatar
Hey guys, just curious what could be the cause of clutch vibration? From what I understand the clutch is relatively new, and it never slips and shifts great through acceleration. The problem is when I'm stopped and I go to take off in first, it vibrates pretty bad right before i depress it and take off. If I were to push the clutch all the way to the floor, it would start vibrating about about 3/4 the way out, so pretty much right before i start to take off. This is a pretty bad vibration too, so what are some causes?
Justin
96 Camaro Z28, mildly modded
2007 Dodge Ram SLT "Big Horn" 4 door
97 Saturn SC1 (DD)
07 GSXR 1000...
I live my life a quarter mile at a time
96 lt1 is offline
post #2 of 11 (permalink) Old 05-12-2011, 02:44 PM
well I can say this..I have same problem clutch was just replaced about 5k miles ago. did everything new except for a new pressure plate all was fine until new motor went in they installer did something to the pilot bearing as he admitted and a few day later the pressure plate was all screwed up when taken apart..my belief is that improper installation of the pilot bearing caused the other damage ...anyway at this point i need a new pressure plate and release bearing...
I hope like hell Jake will chime in here cause he really seems to know alot
anyway it was recomended to me to get the zoom kit which has everything
there are two versions 1. is the MU unit and the other is a high performance kit with a kevlar disc
so i need info on weather to get the couple parts from gm or get the zoom unit
mcseccne is offline
post #3 of 11 (permalink) Old 06-07-2011, 05:11 AM Thread Starter
96 lt1's Avatar
It also does it pretty bad if I'm downshifting.. I forgot to add that. If i go from say, 4th to 3rd, right before i engage into third it will have a hard quick vibration and then go into gear as normal. It doesn't affect the shifting, it's just annoying and tends to make me shift more subtly rather than just popping it into the next gear.
Justin
97 Saturn SC1 (DD)
07 GSXR 1000...
96 lt1 is offline
post #4 of 11 (permalink) Old 07-08-2011, 10:13 PM
Hey man,im new to here but I just recently baught a 96 trans am M6 and it was perfect for the first wk,i literally had it two wks now and it was doing exactly what yours is doing including the vibration when down shifting,im having the place where I got it help me get this fixed,like you said once you got going there wasnt any problem with shifting to any gear I also felt vibration from the car while driving on the highway,not from clutch or tranny.....i think,not sure.....but any ways once I get mine looked at this wk end ill post back here,i cant drive mine at all till its fixed it just went out on me today ;(
Formula420 is offline
post #5 of 11 (permalink) Old 07-10-2011, 03:30 AM Thread Starter
96 lt1's Avatar
Yeah that'd be awesome because it still does it. I'm just dealing with it for now. Have bigger issues like overheating and things. But yeah get back to me asap, I'd like to atleast KNOW what's going on rather than wonder.
Justin
97 Saturn SC1 (DD)
07 GSXR 1000...
96 lt1 is offline
post #6 of 11 (permalink) Old 07-13-2011, 01:29 PM
I explained the problem to the guys who are going to fix the problem and they are saying it sounds like preadure plate is jacked up and cause of the problem could be wasnt installed properly or who ever had it before me didnt do proper break in with it and might have to replace some other shit also,getting my t/a in tomorrow so will know for sure in a few days.its taken so long to get back to you cause the place I got it at kept blowing me off and acting they werent going to help fix the probm....**** that,not even two wks and had problem,mot playing that game....ill get at ya in couple days
post #7 of 11 (permalink) Old 07-26-2011, 08:39 PM
Hey Justin, finally got an answear. .....I was told the throw out bearing was bad and the shift fork went bad but the clutch and preasure plate are still good and not damaged witch is good since that will make it cheaper for fixing it. Probably looking at 5-600 total with parts and labor, maybe cheaper but they didn't say, I'm just assuming. Once I get it on this Thursday ill let you know if the problem is fixed
post #8 of 11 (permalink) Old 07-27-2011, 01:47 AM Thread Starter
96 lt1's Avatar
Throw out bearing huh? I just installed a new B&M Ripper Short throw shifter and it actually helped a little, but still does it. It's at its worst when it's hot. It doesnt do it too bad when i first start driving, but after 20 minutes or so it start to get worse. Obviously the fluid has thinned by that point and heated up so it makes since. You ever done tranny work before? You could save A LOT of money if you replaced that stuff yourself. I scored a tranny for my saturn on CL for 200.00 a few months ago and put it in over the weekend, swapped clutches out and throw out bearing(parts were bad on the new trans, trans was in the car was toast, but parts were good) Tranny shop was gonna charge 0ver 1k so I was like F*** that and did it myself. Pretty simple stuff if you just take your time, especially on a RWD car.But yeah keep in touch, curious what all needed to be replaced. Careful with those mechanics, they can charge you for a bunch of shit that never took place. I'd make random stops and see how things are going from day to day.. unless it's someone you can trust of course. Alright man, take care and good luck!
Justin
97 Saturn SC1 (DD)
07 GSXR 1000...
96 lt1 is offline
post #9 of 11 (permalink) Old 08-05-2011, 08:51 AM
Cool
Hey Justin, since I got the throw out bearing replaced and clutch fork the vibrations are gone and when ibdown shift no more vibration from that either so it seems the problem is fixed in that aspect. .....question though.......when I'm in neutral I hear some chattering under car,I thought maybe it was the engine but once I pused the clutch in the noise stooped?? You got a clue what it might be.....never told the mechanics about it cause I forgot
post #10 of 11 (permalink) Old 08-12-2011, 12:41 PM
97 SS LT1's Avatar
The noise you are hearing is the throw out bearing. If you have a cam..."they" say it's normal. Mine does the same thing.
1997 Camaro SS #695 M6, T-tops, 355 CID, LT, Ypipe, TB bypass, air foil, 52MM TB, 4:10 gears, Electric Cutout, 160 thermostat, EGR AIR delete, K&N air filter, Trickflow Elbow, 8.5MM wires, MSD streetfire coil, 230/244 112 LSA 306 cam, 1.6 RR, P&P heads with valve job, 32lb injectors. Forged alum. pistons, new bottom end. Solomon tune. Ram HD clutch....needs more power!!
97 SS LT1 is offline
post #11 of 11 (permalink) Old 08-12-2011, 12:43 PM
97 SS LT1's Avatar
Have you ever spun the clutch??
