replacing slave cylinder - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 5 (permalink) Old 04-24-2009, 04:38 PM Thread Starter
So I've come to the conclusion that my slave cylinder is bad in my 99 trans am ws6. Do I really need to drop the tranny to replace it?
apg12 is offline
post #2 of 5 (permalink) Old 04-24-2009, 07:09 PM
85MikeTPI's Avatar
You have to at least pull the trans back about 6", out away from the bellhousing. The LS1 slave fits over the input shaft, and is about 6" in depth.
85MikeTPI is offline
post #3 of 5 (permalink) Old 04-24-2009, 07:36 PM Thread Starter
ok thanks again for the help mike. I was hoping it was going to be an easier job but at least I can take a look at the clutch while I'm in there.
apg12 is offline
post #4 of 5 (permalink) Old 05-03-2009, 02:28 PM
jbridwelltransam's Avatar
i dont have to do that for my lt1 do i?
1995 trans am M6, Pacesetter LTS, lt4KM, Moroso CAI, STB, Hurst short throw, and some drilled slotted rotors with new pads all the way around :p
jbridwelltransam is offline
post #5 of 5 (permalink) Old 05-06-2009, 12:57 PM
ProjektNitemare13's Avatar
on an LT1, no, its right there, 2 nuts and its off, but if you do a slave on a LT1 i woudl really recommend just plurging and getting the entire hydraulic system, just from past experiences.
ProjektNitemare13 is offline
