High clutch engagement - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 1 (permalink) Old 02-08-2017, 09:41 AM Thread Starter
I recently replaced my clutch master cylinder and slave cylinder my master cylinder was leaking fluid all over my floor so I figured it was shot. Changed both parts the master was a PITA with that u bolt. But after bleeding the system with the mighty vac and taking if for a test drive I notice that the clutch now engages much much higher than before like the last 2-4 inches at the top of the pedal rather than before it was about 6 inch from the floor. Is this normal??
frankmolinas is online now
