Lt1 OPTISPARK problems??? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 28 (permalink) Old 05-14-2005, 09:51 AM Thread Starter
johntom's Avatar
Send a message via AIM to johntom
ive heard some bad htings about the optispark system on the LT1's have any of you had problems or do you have any other info to share about them?
ya...its slow
johntom is offline
post #2 of 28 (permalink) Old 05-14-2005, 09:59 AM
imported_admin
Guest
Posts: n/a
Re: Lt1 OPTISPARK problems???
Who hasn't had problems with an optispark? LOL. THere's two parts to the opti. THere's an optical cam position sensor. This part is a Mistu build piece and is VERY accurate at reading cam position and delivering timing signals, but its very moisture sensitive.
The other half is the high voltage section where the rotor conducts the spark just like any other distributor. This half can also be affected by moisture and also over time the high voltage creates ozone inside the cap that corrodes the contacts.
They can be reliable if you keep them dry, which can be hard when its mounted on the front of the motor under the water pump. The upside is they are not hard to replace, a little messy with the w/p removal, and they are only about $200 a pop brand new from GM. If maintained properly you shouldn't have to replace it too often.
One mistake a lot of guys make is they add an MSD box onto the ignition. The multiple spark errodes the contacts inside the rotor very rapidly. MSDs have been responsible for lots of opti failures, particularly on boosted cars.
There are some nice options out there to eliminate the opti all together now, including just taking the high voltage side offline and continuing to use the cam sensor part. With the voltage removed from the opti the cam sensor section can live a very long life. Same basic sensor is used on lots of other vehicles out there minus the distributor half.
post #3 of 28 (permalink) Old 08-01-2005, 01:19 AM
Send a message via AIM to F-Bobby
junk it and get Deltech coils. thats all i have to say about that. WORST IGNITION SYSTEM EVER!
"Sits 10 inches off the ground with a Custom plate thats says, I E A T Z 2 8 .... TRANS AM!!"
1987 Pontiac Firebird Trans Am GTA <-- Yeah its real
F-Bobby is offline
post #4 of 28 (permalink) Old 08-12-2005, 10:05 AM
Talking
Just had mine replaced. Cost was a house a car and a leg.
There not cheap and Ive had many mechanics quit on me after doing little things on this car. But you never let on that that is the case. You just smile and wave at the people who stand and drool as you drive by.
Its all worth it in the end.
Rena is offline
post #5 of 28 (permalink) Old 08-12-2005, 12:23 PM
Vendetta's Avatar
Send a message via AIM to Vendetta
People play out opti problems a lot more than they should be. A lot of them are actually due to owner error, like a batched installation.
Vendetta is offline
post #6 of 28 (permalink) Old 08-12-2005, 05:41 PM
Fastbird's Avatar
Send a message via AIM to Fastbird
I've had exactly two problems with opti's.
I powerwashed the engine bay of my black car right after buying it, before I knew better. BIG mistake. Fried it.
Second problem was some corrosion on the harness.....DTC 36, new opti and clean harness fixed it.
1999 Corvette -- Built motor, APS TT, 761/760 on 14 PSI -- FOR SALE $27,500
1993 Trans Am -- 383, LT1Boost Hot Parts, PT76GTS, FAST XFI, ect.....running and slowly being tuned by me
1999 Celica -- Gen II 3S-GTE Swap, 250/260 WHP
Fastbird is offline
post #7 of 28 (permalink) Old 08-12-2005, 07:34 PM
transamtom's Avatar
LMAO,I did the same thing
94 TA GT A4 WS6 Clone,Yank 2800,SLP Headers,DD Subs,Hotchkis,98+Tails DS and Brakes and more...
60ft 1.919 13.417@101.35
95'Bird ! Mods !Times
transamtom is offline
post #8 of 28 (permalink) Old 08-13-2005, 12:51 AM
I've had great success with the Opti...
Check this link as well... http://web.camaross.com/forums/showthread.php?t=360817
Dan Parker '96 is offline
post #9 of 28 (permalink) Old 08-18-2005, 02:11 PM
Send a message via AIM to NXSLT1
I have 149,000 miles on my original opti and have washed the engine a few times, ran it thru a car wash with the under body wash several times and even had a leaking water pump for several months and have never had a problem. The opti gets blamed too much but I think it's hated mostly due to the pain it is to change out. As far as the cap and rotor, it's basically the same thing as the old school stuff and you do have to change them out every now and again, they don't last forever.
NXSLT1 is offline
post #10 of 28 (permalink) Old 08-20-2005, 09:58 PM
A couple of years back when I purchased my 1995 LT1 Corvette I ran into an expensive issue with the optispark, though it sounds (and sounded at the time) like nothing new to these pages - the car started crapping out on me randomly and a ridiculous sum of money and a new ignition system later it was all better. Though I no longer live in the rainy/snowy region I used to, Hawaii has its fair share of rainstorms and I have not had any problems since the fix. My problem originated with a worn down water pump and voila, I was in debt a short time later! But I still love the car (just not the not-so-reliable-OPTI-spark)
Timbothemonster is offline
post #11 of 28 (permalink) Old 08-20-2005, 10:55 PM
Send a message via AIM to SlowPurpleLT1 Send a message via Yahoo to SlowPurpleLT1
my 94's opti took a crap on me and me being young and dumb at the time i took it to the dealership... after it was all said and it cost me 1500... now a few years later and a lil bit wiser i know that it can be fixed for alot less and it can be upgraded.. so if my 95 takes a crap.. im ready... they are a pain but they get a bad rap
SlowPurpleLT1 is offline
post #12 of 28 (permalink) Old 08-20-2005, 11:10 PM
Send a message via AIM to SpAuLdIzZle
mines taking a crap now.....gotta get the wallet out but i cant wait till it is done
SpAuLdIzZle is offline
post #13 of 28 (permalink) Old 08-20-2005, 11:34 PM
make sure it is your opti... i thought mine was going last week but after closer inspection i found a burnt wire... so give evrything a close look...might save you some money
post #14 of 28 (permalink) Old 08-22-2005, 09:34 AM
no its the the opti....i had my coil and ignition module replaces with some other stuff and the coil was just covered in white crap so...pretty sure my plugs and opti look like that too
post #15 of 28 (permalink) Old 08-22-2005, 10:08 AM
contraststriker's Avatar
Send a message via AIM to contraststriker
I've heard high RPMs hurt the opti's...I'm at 141k on the original optispark, consistently shifting at 6-6.2k, and it's doin' fine!
M6 T/A ...sold
contraststriker is offline
