manual fan switch, stupid question - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Old 11-02-2006, 07:43 AM   #1
rsw3284 Apprentice Level Tech III
Default manual fan switch, stupid question
Ok i decided to install a manual fan switch in my 97 t/a, but i'm having a problem finding a good place to run the wire from the engine bay to the inside kick panel (if that's what it's called).. if i run it up top under the window lining it's almost exposed to the elements and i can't find a way to run the wire without the door hitting it (running it into the fuse box)
Sorry for the stupid question
rsw3284 is offline
Old 11-02-2006, 07:51 AM   #2
Are you making your own switch? This is the best way, IMO. Route the wiring this way.
Old 11-02-2006, 08:22 AM   #3
thanks, just what i needed
i have it routed on the driver's side right now, ill move it later on.
edit: i have my line running straight from the engine bay fuse box (coolant fan#1 relay) and a 12V power source inside the kickpanel with a 30A inline fuse on the hotline. Is this a bad idea?
rsw3284 is offline
Old 11-02-2006, 02:23 PM   #4
IMO, it's a bad idea. I would never want to use 12v power through a switch. Too much potential for trouble with something that uses that much current.
Using the normal fan relay control wires gives you override on the fans and still lets them work as normal, without any trouble codes. Your way is going to set a trouble code when the computer sees the fans on when it has not told them to be on. The wiring diagram on my site will not cause any trouble codes.
Old 11-02-2006, 04:09 PM   #5
Firebirdjones Apprentice Level Tech III
Not to be a rotten apple, but I never saw the purpose for this mod unless you are running an electric pump as well and can cool the motor while it is not running. If the computer is reflashed to have the fans come on at lower temps to work in conjunction with a cooler thermostat, there is really no reason that I see, to have a manual override switch.
Is there something I am missing here? Someone please enlighten me. Larry.
70 ram air Formula
72 SS 454 Chevelle
71 454 Corvette
97 Z-28 6-speed Convertable
88 Iroc 350 TPI
56 Nomad
79 Chevrolet 1 ton 454
79 Monza 406 sb
82 Jeep Scrambler (96 LT1, 4L60E)
2005 Rubicon
Firebirdjones is offline
Old 11-02-2006, 04:52 PM   #6
03slowZ06's Avatar
03slowZ06 Apprentice Level Tech III
no your not being rotten. when you hard wire the fans through the fan relay they still work as advertised. but lets say you put in a 160 degree stat and just have free mods on your car. you cant just yet justify a dyno tune because of what you your next mod will be. say h/c. no need to tune it twice right. so put it in to make use of your 160 stat right now and pick up some more power. or say you are taking it to the track on a hot azz day and you have 30 minutes between runs click the fan on while the car is sitting there to help cool things down as much as possible. to some people its a fail safe. if that switch is on then its one less thing to worry about. or atleast these are my thoughts on it.
u can do it
03slowZ06 is offline
Old 11-02-2006, 04:59 PM   #7
Grims's Avatar
Grims user's tech expertise is unknown at this point
I need to rewire mine this way, when I first got the car we had to by pass the PCM all together because the PCM was messed up and wouldn't turn on the fans. Now that I have a new PCM, I'm getting real tired of keeping up with the temps.
Yes, it's the opti.
96 6m Black Trans Am T-Top
Mods: Classified
Grims is offline
Old 11-02-2006, 11:02 PM   #8
crazytglo's Avatar
My Facebook
crazytglo Apprentice Level Tech III
well for me....for some reason my fans do not come on. my engine just heats up and doesnt cool off until i hit the switch or quickly go to highway speeds, so for me its preaty essential, it being my daily driver.
99 Z/28, M6, K&N, SLP LID, TSP Hardened pushrods, aftermarket rocker arms, Borla Catback, LCA's, Pandhard Bar, Front and Rear Swaybar, Eibach springs, Konig Monsoons, Lowered 1.5"
2000 SS, Auto, K&N, SLP Lid, Chokemaster, Cut-out, No Cats, Lowered 1.5", Black ZR1's, KB SFC's---SOLD!
97 SS 30th Annv. Ed., M6, K&N, UMI Short Stick Shifter, 160 thermo, Hooker Headers, No cats, SLP exhaust, Intake elbow, Fan switch.
300 RWHP.....well 298.3.........TOTALED
crazytglo is offline
